Lecker M20 aus USA
Moin, war grad im Amiforum unterwegs und hab dieses technisch schöne Exemplar eines E30 gefunden :sabber: Die Technik ist echt fein, optik solala
hier mal Bilder und Daten:
http://members.shaw.ca/gforce-2/Build%20Photos/front.JPG
http://members.shaw.ca/gforce-2/Build%20Photos/lr%20corner.JPG
Hier eine Interessante hintere Domstrebe die auch auf die Stabiaufnahmen geht
http://members.shaw.ca/gforce-2/Build%20Photos/rear%20brace.JPG
Und jetzt das Bild wo mir erstmal die Kinnlade runter gefallen ist :eek:
http://members.shaw.ca/gforce-2/Build%20Photos/enginebay_r.JPG
http://members.shaw.ca/gforce-2/Build%20Photos/enginebay_l.JPG
http://members.shaw.ca/gforce-2/Build%20Photos/intake%20port.JPG
http://roccosperformance.com/shop/images/M20%20Rocker%20arm.jpg
Hier die Motordaten:
Engine
2.8 liter M20 "stroker"
2.7 block bored +1mm, decked, align bored with ARP main studs
325e 2.7 crankshaft, machined and balanced
Custom forged Ross pistons, static comp ratio of 10.6:1
Eagle 135mm H beam connecting rods with ARP rod bolts
325i "885" cylinder head, fully machined and ported
ARP Head studs
Cometic MLS head gasket
Schrick 288 camshaft
VAC Racing adjustable cam timing gear
PPM Race billet rocker arms, Porsche style adjusters
Metric Mechanic stainless steel valves
Metric Mechanic "beehive" progressive rate valve springs and retainers
Hartge rocker cover
Dbilas Dynamic intake manifold with independent 40mm throttle bodies and Dbilas plenum
19lb per hour Ford Motorsport/Bosch injectors (21lb at 43psi)
Nuke fuel rail
Aeromotive adjustable fuel pressure regulator
Vibrant bellmouth air filter adapter
K&N air filter
Mishimoto E30 M3 aluminum radiator, modified to relocate lower rad hose to opposite side
Canton remote oil filter mount and filter housing adapter, plumbed with Aeroquip braided hose
Ignition / Engine Management
Megasquirt 2 V3 running v2.1extra firmware controlling fuel and spark
Innovate LC-1 wideband o2 sensor and controller
Wasted spark ignition using six S50 Bav Auto coilpacks mounted on custom rail
Electric pusher fan controlled my Megasquirt
GM temp sensors - air, water
Jeep stepper motor Idle Air Control Valve, PID closed loop
Innovate Motorsports gauge cluster mounted in BMP AC delete gauge panel, AFR, WT, OP
hier ein kleines Video
Doch sehr fein was man so alles an nem M20 machen kann
Bearbeitet: von sLothiC
http://i.minus.com/ib2utgn0YyvLfX.gif
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/
Gefällt mir gut. Allerdings muss ich sagen das ich mehr erwartet hätte bei dem Video,so schnell kommt er mir dort nicht wirklich vor,oder das täuscht jetzt extrem,das wäre möglich. Haben die E30 in den usa eigentlich alle die Aussparung im Heckblech für das Kennzeichen?
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075667
Find ich sehr gut, das es noch Leute gibt, die auch beim M20 mal richtig Hand anlegen. Das Video zeugt jetzt nicht wirklich sonderlich von Leistung, aber vielleicht täuschts ja auch.
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075686
Mensch das ist Amiland, das Land der Poser und Kasper. Die 140 die der da auf´m Highway fährt sind erbarmungslose Raserei, auch wenn bei uns ein 50PS Fiesta von hinten drängeln würde. :-D
Über 100 krapfen die Jungs schon am Lenkrad. :devil:
Alleine das er während der Fahrt an dem Pömpel in der Mittelkonsole rum reißen muß, macht den Typen dort schon zu so ´ner Art Rennfahrer....;-)
auto motor & sport 22/86
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075700
*pruuuust*
*kringel*
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075702
schaut schon lustig aus wie er ganz schnell immer gleich gang 3 und 4 rein kloppt.. lol......:-R
den 2. hat er ja wenigstens mal gut durchgezogen.... was auch gut aussah find ich....
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075714
Muhaha ... aus welchem Sexshop isn der Schaltknauf?!
Projekt:
Biete:
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075725
Da kann Frau/Mann wenigstens nicht zu tief einrasten! :-D
Die Domstrebe vorn find ich sehr interessant bzw. den Motorraum im allgemeinen. :daumen:
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075730
jup Motorraum is klasse.... die Optik vom M20 auf alle fälle... die Zündspulen... die Sauge.... echt geilo..... und nimmt auch richtig geil das gas an....... so muss das sein....
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075955
Weis einer was das hinten für ein Spoiler is, der würde meinem VVfl auch sehr gut passen=)
...Moment, ich schaue mal kurz in meinen Fahrzeugschein : ;-)
"Heckspoiler Hartge, Kennzeichnung 51475 (Kennz.unterhalb Querleitwerk)"
Gruß, Pit :sonne:
Gruß, Pit :sonne:
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075959
Gruß, Pit :sonne:
Den Spoiler kenn ich doch :-p
Sieht echt nett aus, das Motörchen ! :daumen:
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075993
eigentlich schade das man nix zwecks Leistung auf dem Papier sehen kann.... am Motor is schon alles echt lecker gemacht....
Übermaßkolben, 288er Schrick, DBilas Sauge, Kopfbearbeitung, Freiprog. usw...
nur schade das man so einem Motor dann NUR ein 4.10er Diff verpasst....
is ja kein wunder das der auf dem Video so "schön" durchzieht.....
mit dem richtigen Diff würde der bestimmt noch besser laufen..... WENN die Freiprog auch perfekt programmiert is.. was ich doch mal annehme bei dem riesen Aufwand.....
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1075996
Gruß, Pit :sonne:
Is wahrscheinlich sehr selten das Teil oder?
Eingefügtes Bild
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1076599
Gruß, Pit :sonne:
...Ja, der ist recht selten, aber trotzdem sind 2011 allein hier im Talk-Marktplatz 2 Exemplare angeboten worden.
Einen davon habe ich gekauft, der andere wurde recht lange angeboten, keine Ahnung, ob der mittlerweile verkauft ist.
Außerdem hatte ich bei Ebay 2 Stück gesichtet ohne gezielt danach gesucht zu haben.
Preislich lagen alle zw. 70 bis 100,- (inkl.Versand).
Gruß, Pit :sonne:
Gruß, Pit :sonne:
https://e30-talk.com/topic/81716-lecker-m20-aus-usa/#findComment-1076650
