Finsk Geschrieben: 5. Dezember 2011 #151 Meldung Teilen Geschrieben: 5. Dezember 2011 Morgen, am 6. Dezember ab ca. 9:00 Uhr kommt der ca. 2GB große Patch für PC, hier mal die Fixes aus dem Battlelog Forum: BugfixesFixed a problem with spawn timer now showing blue border on startup and lost spawn pointFixed a problem where player who joined queuing on End of round got spawn screen stuck on screen, but unable to do anything with it untill next round loadedFixed a problem where camera would change to 3rd person on killcam when killcam was turned off in server settingsFixed stat references on several dogtagsFixed for surveillance ribbon not counting TUGSFixed a missing combat area lines on the minimap for Grand Bazaar conquest smallMoved a tank spawn in US base on Caspian Border so it would not be destroyed by a falling treeFixed a problem where placing C4 with the russians soldier was playing US faction VOFixed a problem where TV guided missiles could be shot into its own helicopter and destroy itFixed a problem when attempting to fire lock on weapons without a targetTweaked the chat, it should now be a bit easier to readFixed several vehicles that did not properly shoot rockets and guns towards their predictive sightsFixed the G17 Supressed Laser not working properlyAdded alternate HUD colors to help colorblindsAdded a network interpolation setting. This allows users with good bandwidth reduce latency, but might increase some stuttering. The user can find what works best for his connection by tweaking the slider.Increased the Spawn protection radius on TDMFixed a problem with smoke on land vehicles, Missiles should now miss more oftenFixed a problem where users could end up with IRNV scope in any vehicleFixed a problem where player dies if vaulting over a ledge and into water while sprintingFixed several crashes and increased general stabilityFixed a problem where the user was unable to revive two players that have the bodies one over the otherFixed so you can assign an axis and use as a digital input. This makes it possible for the player (on pc) to assign one of the sticks on a gameped to be used for throttle/brake.Fixed a problem with the Kill camera acting up when suiciding from parachuteFixed air radar was showing to much. now lasertagged, heatsignature above threshold, enemy missiles and capture points are only visible on air radarFixed a problem where the game would enter a technical hang if the user pressed pause menu and tilde at the same timeFixed a problem where you could get green flashes on screenYou can now reassign cycle weaponsFixed so the weapon zooms automatically after bipod deploy is gone when using zoom toggleFixed a problem where the parachute would stay stuck in air if the owner was killed Balance TweaksFixed several weapons so they are properly suppressed and hide the player on the minimap when fired.Tweaked Tactical Light so it is not as blinding over longer ranges.Tweaked the IRNV scope so it is limited to usage only at close range.Reduced heat masking effectiveness of Spec Ops Camo.Fixed a bug where Ammo spec would give additional 40mm grenades instead of Frag spec.Increased the number of additional 40mm grenades from Frag spec.Fixed so AT mines only live for 20 seconds after a player dies to prevent infinite mines. (We want to make a different fix in the future, it’s in JIRA).Increased the Time to Live on sniper caliber rounds to allow extreme distance shots.Fixed several weapon descriptions, calibers, and fire rates. The weapons themselves have not changed.Fixed so the M9 and MP443 pistol can be equipped by the opposing faction when it is unlocked at 100 kills.Fixed Laser Guided Missiles missing their targets if the target is moving too fast. Reduced the effectiveness of Stealth on Air Vehicles.Reduced the effectiveness of Beam Scanning for Jets.Reduced the damage done to Armored Vehicles and Infantry from AA guns.Increased the damage RPGs and Tank shells do to AA vehicles.Slightly decreased the accuracy for all weapons on fully automatic, burst fire is now preferable at mid to long range.Increased the effective accuracy of long bursts for LMGs when using a bipod.Slightly increased the range of the 44magnum bullets.Increased the close range damage of 4.6x30mm and 5.7x28mm bullets.Increased the reload time of the Mortar from 3.5sec to 4.8sec and increased the time it takes before a shell hits the ground.Reduced the aimed accuracy bonus given by a Suppressor for the MP7, P90, PP2000, PP-19, and UMP45.Increased the range and FOV for designating targets with the SOFLAM and vehicle Laser Designators.Decreased the effectiveness of 12g FRAG ammo when equipped on semi-automatic and automatic shotguns.Slightly Increased the power of Fighter Jet Cannons against all vehicle targets, especially Helicopters.Decreased the power of Miniguns against Jets and Helicopters.Increased the power of Stingers against Jets.Flares reload times for Jets and Helicopter Gunners have been increased.Tweaked the AN94 so its burst fire better conveys the real world advantage offered by this weapon.Added Single Shot to the AN94 as an available fire mode.Slightly increased the recoil on the M416 and removed the Burst Fire mode (this weapon incorrectly had burst fire, which was not authentic).Tweaked the spawns for TDM on Kharg Island, Grand Bazaar, Caspian Border, Seine Crossing, Operation Firestorm, Damavand Peak and Noshahar CanalsMoved a tank spawn in US base on Caspian Border so it would not be destroyed by a falling treeTweaked the Gas station Capture area on Conquest on Caspian BorderTweaked the max vehicle height on Noshahar Canals Quelle: http://winfuture.de/news,66950.html / http://battlelog.battlefield.com/bf3/forum/threadview/2832654489494744784/ P.S.: Hoffe der behebt nun mal einige Probleme. Zitieren MfG Stefan Das ist kein Rost, das ist Pubertät im späten Stadium Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1072458 Auf anderen Seiten teilen Weitere Optionen zum teilen...
jannis320iM20 Geschrieben: 8. Dezember 2011 #152 Meldung Teilen Geschrieben: 8. Dezember 2011 Bei mir läufts seit dem patrch ohne probleme, keine disconnects, kein battlefield funktioniert nicht mehr kein garnichts.Leider haben sie das ifrarot teil kaputt gemacht. aber mir taugt das acog eh mehr.ansonsten muss ich sagen so hätt ichs von anfang an erwartet.hoffentlich ist bald der 13.... Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1073866 Auf anderen Seiten teilen Weitere Optionen zum teilen...
D-FENCE Geschrieben: 8. Dezember 2011 #153 Meldung Teilen Geschrieben: 8. Dezember 2011 ich hab auch schon gelesen das wohl alle probleme behoben sein sollen, irgendwie mag ich es noch nicht glauben, na ich bin mal gespannt, hab jetz zum glück mal nen paar tage frei und werd wohl auch mal wieder zum zocken kommen :) Edit : Also der Patch hat rein garnix gebracht, stürzt immer regelmässig ab, hängt sich auf sobald ich im Panzer sitz usw. Allerdings hab ich nun endlich die Lösung gefunden, auch wenn sie nicht ganz billig war *lol* Windows 7 64bit .... hab das vorhin mal installiert und siehe da BF3 läuft stabil..... Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1073978 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Jan324td Geschrieben: 10. Dezember 2011 Autor #154 Meldung Teilen Geschrieben: 10. Dezember 2011 Tja Dave auch Win7 64Bit ist nicht die reine Lösung aber hilft ungemein. Sag mal hast du noch ne alte Graka rumliegen die besser ist als ne 3870? Zitieren Special Notice!!!Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market and economic conditions,"The Light at the End of the Tunnel" has been turned off.We apologise for the inconvenience.GrußJan :beemwe:Frauen, die meinen, Männer seien zu keiner innigen und liebevollen Beziehung fähig,waren noch nie am Samstag in einer Autowaschanlage!Zum Thema Komplimente:"Unter allen Arschgeigen bist Du die Stradivari"♥ ♣ ♦ ♠ ♥ ♣ ♦ ♠ dem Waidmann jede Pirsch behagt,sei`s auf den Hirsch,sei`s auf die Magd.der sogenannte gute Mensch, ist des Idioten bruder! Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1074667 Auf anderen Seiten teilen Weitere Optionen zum teilen...
D-FENCE Geschrieben: 10. Dezember 2011 #155 Meldung Teilen Geschrieben: 10. Dezember 2011 Tjo die reine lösung isses nicht, aber da ich eh auf viel mehr Ram umsteigen werde, war Win7 64bit sowieso nötig, und da ich eh mal nen OS aufm Raid haben wollte hat sich das jetz bestens angeboten. Mein W7 32bit werd ich aber trotzdem behalten, für was hab ich den jetz mittlerweile 6 Festplatten im Rechner Aber ey BF3 lief jetz 3 stunden am stück stabil, und das obwohl ich wärend das Game lief nen haufen kram am System eingestellt hab und installiert hab, ich bin überrascht. Grafikkarte habsch keine mehr, meine lezte PCI-E hab ich vor paar wochen hier im Forum verschenkt. Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1074687 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Finsk Geschrieben: 17. Dezember 2011 #156 Meldung Teilen Geschrieben: 17. Dezember 2011 So, mir war eben langweilig und es fehlt ja noch ein E30-Talk Platoon http://battlelog.battlefield.com/bf3/de/platoon/2832655241140258724/ Zitieren MfG Stefan Das ist kein Rost, das ist Pubertät im späten Stadium Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1077919 Auf anderen Seiten teilen Weitere Optionen zum teilen...
jannis320iM20 Geschrieben: 19. Dezember 2011 #157 Meldung Teilen Geschrieben: 19. Dezember 2011 bei mir gehts seit heute nichtmehr, liegt wohl am punkbuster. neu installiert, auch den graka treiber, nix. nach 1-3 min bin ich disconnected.es kotzt mich an. Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1079019 Auf anderen Seiten teilen Weitere Optionen zum teilen...
jannis320iM20 Geschrieben: 3. Februar 2012 #158 Meldung Teilen Geschrieben: 3. Februar 2012 (bearbeitet) ...Kann jedem nur von diesem Spiel abraten! Bearbeitet: 3. Februar 2012 von jannis320iM20 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1100978 Auf anderen Seiten teilen Weitere Optionen zum teilen...
D-FENCE Geschrieben: 3. Februar 2012 #159 Meldung Teilen Geschrieben: 3. Februar 2012 jetz mal ruhig blut, Origin hat heute scheinbar erhebliche probleme, dies muss aber nicht an EA liegen ( Dice hat ohnehin damit nix zu tun ) kann sein die deppen von Anonymus oder irgend ne andere Hacker deppen sich mal wieder überlegt haben Origin oder Punkbuster zu hacken wie in lezter zeit öfter schon vorgekommen. Wart einfach mal bisl ab, und das problem wird sich beheben. Jedem dieses spiel abzuraten halt ich hier auch nicht für den richtigen Weg. Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1100997 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Jan324td Geschrieben: 3. Februar 2012 Autor #160 Meldung Teilen Geschrieben: 3. Februar 2012 Funzt doch wunderbar weiß nit was ihr alle habt. Zitieren Special Notice!!!Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market and economic conditions,"The Light at the End of the Tunnel" has been turned off.We apologise for the inconvenience.GrußJan :beemwe:Frauen, die meinen, Männer seien zu keiner innigen und liebevollen Beziehung fähig,waren noch nie am Samstag in einer Autowaschanlage!Zum Thema Komplimente:"Unter allen Arschgeigen bist Du die Stradivari"♥ ♣ ♦ ♠ ♥ ♣ ♦ ♠ dem Waidmann jede Pirsch behagt,sei`s auf den Hirsch,sei`s auf die Magd.der sogenannte gute Mensch, ist des Idioten bruder! Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1101001 Auf anderen Seiten teilen Weitere Optionen zum teilen...
jannis320iM20 Geschrieben: 3. Februar 2012 #161 Meldung Teilen Geschrieben: 3. Februar 2012 Es läuft mit ausstellen meiner windows firewall... denke nicht, dass es mit nem hack zu tun hat. Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1101005 Auf anderen Seiten teilen Weitere Optionen zum teilen...
D-FENCE Geschrieben: 3. Februar 2012 #162 Meldung Teilen Geschrieben: 3. Februar 2012 Naja das ja wohl logisch wenn deine Windows Firewall Origin blockt, das dann nix geht ;) Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1101006 Auf anderen Seiten teilen Weitere Optionen zum teilen...
jannis320iM20 Geschrieben: 4. Februar 2012 #163 Meldung Teilen Geschrieben: 4. Februar 2012 ja aber das hat ja vorher auch die ganze zeit funktioniert. wenn innerhalb 2 std über 4000posts zu diesem thema erscheinen liegt das problem siche rnicht (nur) an mir. werds zocken damit jetzt erstmal sein lassen und warten bis der mist evtl richtig funktioniert. zock ich lieber wieder BF2 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/79437-battlefield-3/page/7/#findComment-1101052 Auf anderen Seiten teilen Weitere Optionen zum teilen...
