E 30 fuer bis 20.000 $
Auch wenn es nur australische $ sind, Wahnsinn. Das kommt durch die Restriktionen in AUS zum Schutz der lokalen Produktion.
Hier der Zeitungsbericht
http://www.drive.com.au/editorial/article.aspx?id=11139&vf=7&bg=38&pp=1
Aber macht Euch keine Hoffnnung jetzt alles nach AUS zu vertickern :-[
Neue Importe werden wahnsinnig hoch besteuert und sind erst ab einem gewissen Alter erlaubt.
ESV-Rep-saetze ab Lager lieferbar, siehe Kleinanzeigen
https://e30-talk.com/topic/15059-e-30-fuer-bis-20000/
Ist zumindest für die US, ein ganz normaler 325i, hat nix mit M-Technik zu tun!
http://www.icixsound.com/vb/icixnation/images/2439_1.jpg
Zitat
https://e30-talk.com/topic/15059-e-30-fuer-bis-20000/#findComment-160839
Hab mir noch mal die Importbestimmungen mitteilen lassen fuer Australien:
IMPORT RULES
The following is a guide for importing vehicles as the Australian government only allows vehicles to be imported if it falls under one of the following categories.
PERSONAL IMPORT
If you currently live overseas and have had a vehicle registered in your own name for a continuous period of more than the last 12 months, then you are eligible to import your vehicle to Australia when you return to Australia, or become an Australian Citizen.
15 YEAR OLD VEHICLE
If a vehicles manufacture date is more than 15 years ago, then that vehicle can be imported to Australia without limitation, or restriction.
MOTOR-SPORT
Motor vehicles can be imported for Motor-sport competition. The vehicle can never be registered for non-motor-sport purposes.
WRECKING
Vehicles may be imported for wrecking purposes. It is a condition that the vehicle arrives with the body in more than one piece and can never be registered for road use.
LOW VOLUME COMPLIANCE
Vehicle importation is conditional to it being complied to Australian Design Rules (ADR) immediately it arrives in Australia by a Compliance Plate Holder (CPA). To become a CPA a company must provide evidence to the Federal Office of Road Safety (FORS) that the vehicle meets each ADR. Where the vehicle does not comply with an ADR, the CPA Holder must show how they intend to overcome it, with the use of engineers plans for modifications, or alternative parts etc. This process can take up to 2 years to complete, and only then can that CPA holder comply up to only 25 vehicles per year.
The vehicle must also meet certain criteria at the time of the CPA Application, such as
it must not be available in Australia from the manufacturer,
the vehicle must be considerably different to that offered by the manufacturer,
if it is a passanger vehicle, it must not have 4 doors if newer than 1995
https://e30-talk.com/topic/15059-e-30-fuer-bis-20000/#findComment-160869
Das scheint in Down Under wohl anders zu sein. In dem Text wird der 325is neben dem 320i und dem 325i als Modellmöglichkeit erwähnt. Ich denke auch eher, dass der 325is ein 325i mit M-Tech ist.
20.000 AUD sind aber immerhin 12.360 EUR! :eek:
https://e30-talk.com/topic/15059-e-30-fuer-bis-20000/#findComment-160930
schade das es immer wieder leute gibt die einem steine in den weg legen, der wäre sicher hier auch wieder verkäuflich.
schön das er net abgeschrieben wurde in der autoindustrie. aber was will man preislich sagen..... ich habs leider net... noch net :D
Cirrusblaue Grüsse JJ
https://e30-talk.com/topic/15059-e-30-fuer-bis-20000/#findComment-160935
  • 2 Wochen später...
Hi,
wollte nur kurz mal was zur Aufklärung beitragen.
Die "is"-Modelle waren (zumindest in den Staaten) die Zweitürer. Hat mich vor langer Zeit auch verwundert, als ich mal 325is gelesen hatte. Dachte das wäre DIE ultimative Waffe ;-)
Also. is hat gar nix mit M-Technik zu tun. Lediglich 2 Türen weniger.
Hoffe geholfen zu haben, wenns auch schon etwas älter ist.
MfG
SportEvo
Drehzahl kompensiert Hubraum :daumen:
https://e30-talk.com/topic/15059-e-30-fuer-bis-20000/#findComment-164560
