drencrom Geschrieben: 18. Oktober 2005 #1 Meldung Teilen Geschrieben: 18. Oktober 2005 wieviel wiegt eine 15" kreuspeichenfelge? Zitieren "as your attorney I advise you to drive at top speed otherwise it will be a goddamned miracle if we can get there before you turn into a wild animal" "30 minutes - it was going to be very close." "He looked serene. I raised his eyelids and it was clear from his pupils that he had a massive brain injury. We lifted him from the cockpit and laid him on the ground. As we did, he sighed and, although I am totally agnostic, I felt his soul depart at that moment." Link zu diesem Kommentar https://e30-talk.com/topic/12570-15-kreuzspeichen-gewichtsfrage/ Auf anderen Seiten teilen Weitere Optionen zum teilen...
helheb Geschrieben: 19. Oktober 2005 #2 Meldung Teilen Geschrieben: 19. Oktober 2005 . Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/12570-15-kreuzspeichen-gewichtsfrage/#findComment-123884 Auf anderen Seiten teilen Weitere Optionen zum teilen...
drencrom Geschrieben: 20. Oktober 2005 Autor #3 Meldung Teilen Geschrieben: 20. Oktober 2005 vielen dank Zitieren "as your attorney I advise you to drive at top speed otherwise it will be a goddamned miracle if we can get there before you turn into a wild animal" "30 minutes - it was going to be very close." "He looked serene. I raised his eyelids and it was clear from his pupils that he had a massive brain injury. We lifted him from the cockpit and laid him on the ground. As we did, he sighed and, although I am totally agnostic, I felt his soul depart at that moment." Link zu diesem Kommentar https://e30-talk.com/topic/12570-15-kreuzspeichen-gewichtsfrage/#findComment-124250 Auf anderen Seiten teilen Weitere Optionen zum teilen...
