iX: 2ter Gang geht nicht rein, wenn kalt
am Am 15.11.2014 um 19:01 schrieb 325i VFL:
Beim selbigen Problem hatte ich mal an Getrag eine Mail geschrieben. Das ist die Antwort:
Der iX sollte ja auch ein 260er Getrag verbaut haben.
Hello guys, am not speaking Deutsch, so please use translator like me :) ok i have E30 1985 m10 getrag 240 5 speed gear, last day i start to change transmission oil, so some people say SAE 80 GL4, other Say ATF, and other say check label ( i don t have label), ok so when i open the drain screw the oil was  red and like water is definitley ATF, but i put Ravenol MZG Sae80 GL4, and the gearbox start work more quiet but other problem it to be second gear when is cold... now i don t know to stay in SAE80 or comback to ATF, but i find the original BMW handbook and i find some intresting think, propably BMW Service change the original SAE80 to ATF in second inspection just check
https://e30-talk.com/topic/109575-ix-2ter-gang-geht-nicht-rein-wenn-kalt/page/2/#findComment-1796384
