Oysrell Geschrieben: 1. Februar 2012 #1 Meldung Teilen Geschrieben: 1. Februar 2012 Hello! I am from Norway. I have a 1990 325ix touring, and I have problems with my climate control.I have changed som sensors, the watervalve ! And I changed the heater controll today (part Number 64 11 1*386*822). I have also checked a motor that control a Arm (that changes between hot and cold air) What happens is that if I turn the heater controll to hot, and rev the engine over 2000 rpm I can hear a knocking sound from the water valve. But if I am under 2000 rpm its working. But I can only choose max hot or cold. I really need help to figure out this problem! Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/83344-e30-325ix-heater-controlclimatecontrol-problem/ Auf anderen Seiten teilen Weitere Optionen zum teilen...
André Berger Geschrieben: 2. Februar 2012 #2 Meldung Teilen Geschrieben: 2. Februar 2012 Hi, if it´s nocking from the heatingvalve, the waterhoses are reversed. Change the both positions of the hoses in the engine room and the nocking will be eliminatet. Best Regards Zitieren <3 Haters Link zu diesem Kommentar https://e30-talk.com/topic/83344-e30-325ix-heater-controlclimatecontrol-problem/#findComment-1099902 Auf anderen Seiten teilen Weitere Optionen zum teilen...
André Berger Geschrieben: 6. Februar 2012 #3 Meldung Teilen Geschrieben: 6. Februar 2012 And now? Does it work? Zitieren <3 Haters Link zu diesem Kommentar https://e30-talk.com/topic/83344-e30-325ix-heater-controlclimatecontrol-problem/#findComment-1102233 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Oysrell Geschrieben: 6. Februar 2012 Autor #4 Meldung Teilen Geschrieben: 6. Februar 2012 And now? Does it work? DANKE ! Sorry for the late answer ! I have been scratching my head on the heater, and no one has told me about the hoses ! I guess the past owner must have changed them. Then when I changed the valve I just did the same ! But works like a charm now ! The temperature on the temperature dial is still on low. But I am going to change the sensor tomorrow. Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/83344-e30-325ix-heater-controlclimatecontrol-problem/#findComment-1102240 Auf anderen Seiten teilen Weitere Optionen zum teilen...
