Kurt66 Geschrieben: 4. Februar 2015 Autor #26 Meldung Teilen Geschrieben: 4. Februar 2015 then on to the splitter. It's made up of two skins which are hollow in between.I didn't want to use a large headed bolt to tighten it and end up squeezeingthe two skins together, which would probably cause it to crack over time,so, two little holes either side of the main one on just the bottom surface.... ream all 3 of them into one... and cut up a little reinforcing plate... slip it in to hole (large hammer kept nicely out of picture).... bolt the plate down tight to straighten it out once in place.... remove bolt, tape up top side of hole.... and pour in some resin to keep everything from moving around.... when the resin dries, redrill the hole, insert the bolts and bolt itall up, which leaves it looking like so.... after that was done it was on to sanding all the little bits and bobs.... and then, finally, just one panel left to finish the prep work.The bonnet... this had been dipped along with the shell and because of thisthe bonder that bonds the skeleton to the bonnet skin was longsince dissolved which left the bonnet feeling fairly flexible and weak'You could feel some new dents on the surface courtesy of SPL,the most noticeable of which was this one.... Still, how bad could they be, few hours and all this would be finished.... It looked like the whole bloody circus had just marched over it!I couldn't fill all them dents, the front tyres would burst under theweight of the filler. So, dial tone, "hello, that BMW?, can I have the parts department please" "hello parts, can you give me a price for an e30 bonnet please"..."no you must have misheard me I only need the price for one please".."HOW MUCH"... dial tone one secondhand bonnet later... nice and clean, no rust, very little stone chipping, and most importantlyno evidence of previous circus marching.... quick block sand with 320 grit revealed only some small dents... and some nudge marks across the front from some over zealousclosing of the bonnet.... an hour had them filled and sanded.... and then on to underneath. As this bonnet was from a 325 it hadthe sound proofing glued on as opposed to the m3's clipped on mat.A steam cleaning took care of the heavy sound proofing but thisstill left the glue residue... an hour with thinners and a scotch pad got the bonnet clean andme stoned from the fumes.... which was convenient as it helped block out the pain from havingto sand every inch of the underneath.... after that, a quick sand of the boot, interior and the engine bay.Spent a little more time in the engine bay getting all the seam sealersanded smooth, I don't like the factory finish brush marks look. and then finally it was time to get ready for some primer.Only problem was the garage was an inch thick in dust andsomeone had filled it with various crap over the last 12 months a quick wipe of a rag later.... and the expert installation of the "Spray booth 3000" complete with NASA spec airlock.... car was put back on wheeled dolly during cleaning andwheeled outside to have the dust blown out of all the cracks andcrevices (neighbours really love me now, and I even offered todo their washing again for them, no pleasing some people).With the place now clean and the car back in we could start taping upthe shell.... the first coating of filler primer is only going on the large panelsurfaces, so everything else gets taped up...... STAY TUNED Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467320 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 5. Februar 2015 Autor #27 Meldung Teilen Geschrieben: 5. Februar 2015 managed to get a small bit done again since the last post,so, roll a fat one or crack open a beer cause here comes the boring details. As it finished up in the last post the car was taped up and ready forfiller primer. As you may have noticed from the previous pic's onlythe large surface area's were getting a coating of the filler primer,and the reason for that is as follows. From my limited understandingof bodywork there's 3 main types of filler or to put it another way3 different layers of crap you can plaster on the outside of your carin an attempt to get it as smooth as possible. Taking them in order ofthickness they are, first, isopon, filler, bondo, call it what you will, it'sthe stuff you've seen me shovel on to the car already. Then there's stopperswhich we'll get to in a while and finally theres filler primer, which we'reabout to spray on now. Filler primer is much the same as normal primer it's just applied alotheavier to build up a thicker coat. The reason for using filler primer?Although the fillers was block sanded down smooth the shell is still notsmooth enough for the top coat yet, the spraying and sanding of the fillerprimer will get it the last step. Plus, unlike metal, filler is porous andwill absorb some paint, if the shell was just given a quick coat of primerand then top coat the paints can sometimes sink down on the filler spotsleaving your beautiful pride and joy looking like it was sprayedby a blind man with aerosol cans in a force 9 hurricane.(may be a slight exaggeration). And this is how it went, after the car is taped up all the panels are given a quick rub downwith this stuff. It's called panel wipe or pre-cleaner and is a weak versionof standard thinners. It should clean off any crap that could react withthe paint going on... with the car now clean and ready to go theres one small job to do beforepainting and thats set up somewhere to clean the gun and mixing potsafter your finished. The items used are, 1 gallon can of standard thinnersto clean with, tools for dismantling the gun, some rags, a scotch padand an empty can for the dirty thinners. The professional work benchpictured below should be available from your local snap-on dealer. the reason for setting up the cleaning area before hand is, from pastexperience, once you are finished spraying, the paint in and on the varioustools you've used tends to dry and harden quite quickly. Should youwish to take a more laid back approach to cleaning up afterwards thenthese are the only tools you will require.... then back in to the "spray booth" itself. While spraying in a confinedspace the paint fumes and overspray will start to build up and the needwill arise to extract these somehow. This will require the use of a highlyexpensive, state of the art, high volume air extraction and filtration unit.Unfortunately on the day I visited the local hardware store to purchasethis they had just sold out, so, instead I've ended up with a 6 inchfan which would struggle to suck a fart from a fly's arse. This coupled tothe length of flexible hosing you see below would be our state of the artextraction system.... on a clear starry night, if you look just right at the correct angle, youcan just about make out the little hole in the ozone above my house. Once suited, booted and masked up the last preparation before mixingthe paint can be done and it's the application of this stuff.... you've no idea where i'm going with this one have you? Let me explain.A long while ago after spraying the interior on an orange rally car I becameacutely aware that the piece of your face not covered by the gas mask can becomecovered in a light coating of the paint your using as it blows back off the area yourspraying. When that colour is orange and you spend the next several days lookinglike an Umpa-lumpa from Willy wonka's chocolate factory it focuses the mind onfinding a solution. Hence, the Vaseline, spread a little on exposed face to avoid this.... the compressor is placed outside so the noise of it doesn't drive you insane... and the shell is given a final wipe over with a "tac rag". (Lint free ragwith some sticky gue coated on them so all the tiny dust crap sticksto it rather than your car)... Then on to the paint itself, I know nothing about paint, but as this isthe internet and 50% of what you read on it is lies and the other 50%bullshit, I will attempt to maintain the high standard.The stuff below is what makes up 2 pack paint, on the left 4 litresof filler primer, in the middle 5 litres of 2 pack thinners (which isdifferent to standard thinners) and on the right 1 litre of 2 pack hardner.... which shall be mixed in to this old paint pot.... with the aid of this.... it's a paint stick. Basically a graduated ruler which letsyou mix 4 parts of this with 1 part of that withouthaving to guess... one side is for top coat which is usually 2 parts colour to1 part hardner with 10% thinners.And the other side is for primer's as most primers are mixed4 parts primers to 1 part hardner and up to 1 part thinnersdepending on how thick/thin you want it, like so..... paint... hardner.... and then thinners, by which stage you should have messed enough allover your hands to make using a camera impossible.When stirred up and mixed well, it's poured in to the spray gun.... through these paper filters to catch any little crap that'll clog the gun... then hook it up to the air line and spray like the clappers. It can behelpful to have an old panel in the booth so you can practice thetechnique of getting runs in your paint so that you have it masteredwhen you turn your attention to the shell... the results of which came out looking like this.... after spending the guts of a year working on a mutli coloured shell it'sactually nice to see it all one colour again, even if it is grey. Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467564 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 5. Februar 2015 Autor #28 Meldung Teilen Geschrieben: 5. Februar 2015 After the paint has had time to dry and settle it's on to the applicationof this stuff... It's a powder guide coat as opposed to the aerosol type one usedearlier. The main difference being that the spray on one will helpshow up dips and bumps in the panel work while sanding, while this stuffwill show up everything till the surface is sanded completely flat.The bottom part contains the coating which is like lead pencil dust,while the top half is the sponge you use to apply it.... pick a panel.... and start rubbing it on.... and if you look closely you'll see just how far from perfect the nicecoating of primer is.... what you can notice is that paint doesn't go on silky smooth but ratherbuilds up like a coating of millions of minuscule little snow flakes leavinga sort of orange peal effect. The other thing you can notice is the remainingscratches from the 80 and 120 grit sanding. So, with the whole panelcovered in guide coat.... it's out with the long sanding blocks again and together with some320 grit sand paper it's back to everybody's favourite pastime.More f**king sanding.... the 320 grit is fairly fine grit paper and blocks are being used fairlylightly compared to earlier but there's still a bit of scope to flattenout any small imperfections as you can see there's a nice thicknessof paint to work with... to illustrate this, the rear quarter panel was showing up a lot of scratch marks left over from the earlier 80 and 120 grit paper.... and as this is blocked down you can see the marks slowly startingto go..... first the lighter 120 marks go, just leaving the deeper 80 grit.... and after some more rubbing they go too, and if you've applied enoughcoatings of the filler primer you'll get them out before breaking throughto the metalwork underneath. (we used 2 heavy coats).... at this stage it's probably worth pointing out that if your planning onhaving a go at something like this then buy, build or rob yourselfa spit. Being able to turn the car to any angle you want to makeyourself more comfortable while sanding is priceless.Sanding is a horrible enough job without adding a broken back intothe equation. with the shell done the doors and bonnet get the same treatment.... the other thing that gets a little attention is the edges of the panels.The more paint you have on the edge of a panel the greater thechance that when you whack it off something a large chip will comeoff it. You might notice that with a door or bonnet that has beenresprayed over the original paint work that when it gets stone chippedthe flakes are usually fairly large as opposed to an edge that only hasthe normal amount of paint on it, which when chipped usually flakesa much smaller chip. So, all filler primer is removed from the edges... Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467565 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 5. Februar 2015 Autor #29 Meldung Teilen Geschrieben: 5. Februar 2015 carrying on from where we left off last night, and it's on to the final ofour 3 types of fillers. With the heavy fillers on and filler primer done and rubbeddown it's time to break out the stoppers.After rubbing down the black guide coat on the shell and separate panelsit's not uncommon to find some little tiny holes in the surface of thefilled area. These are tiny little air bubbles that sometimes get trapped in thefillers as your spreading it on, and will show through the final top coat ifnot dealt with. Kinda hard to see them they're so small but since I can'tfigure out how to use the zoom on the camera your just going to have toshove your face up close to the monitor... along with these tiny holes, block sanding the guide coat also showedup a few larger blemishes that would also have to be dealt with.... The last few larger one's shown above can be filled with a thin covering of fillers,but theres no point trying to fill the tiny pin holes with fillers, it just won't fit.So, we use this stuff.... as you can see by the label 3M have decided to call it "Acryl Red Putty"probably cause they couldn't charge you enough if they just called it "stoppers".Basically it's just a very fine, runny, light form of normal fillers thathas the advantage that it'll fit into any little scratch or pin hole. You canbuy it in a tin or a tube like above. The tube seems to be handier for thesimple reason that this stuff already has the hardner premixed in it, sothe minute it's exposed to the air it starts to go off. With the tube you cantake a little out at a time but the tin version seems to go hard after onlyopening it a few times. Then again I'm not exactly the fastest worker.So, squirt a little out to use... and apply it to the one or two pins holes on the car along with thethin coat of fillers for the bigger blemishes.... well maybe a little more than one or two holes... if you ware spectacles it helps to clean them before this job or youmay use half the tube before realising it's dirt on your glasses notpin holes on the car... the stoppers goes off fairly quickly and can be sanded away usuallywithin 10 minutes. As it's so fine and light it sands much the same asthe primer, so just gently rubbing it with some 320grit takes away theexcess.... to leave just the little bit filling the pin holes...(you'll have to take my word on it) the larger bits of normal filler take another small covering of guide coatand a light block sanding again to get them down flat.... and with all that done around the shell and separate panels the bodyworkis finally as flat as we can get it..... it's then time to clean up the.... and start taping up for final coating of primer.... as everything now needs to be coated fully in primer it's decided to breakit down in to three sessions. First the underneath, inside, engine bay andboot and then later the outside and finally the doors and bumpers and other stuff.We decided to do it like this because theres just so much square footageof bodywork to be sprayed on the car it would be hard not to get oversprayon panels that were starting to dry while your just getting around tospraying the area next to it. Plus with our magnificent, money no object, extraction system there was a good chance one of us would probably diefrom toxic fumigation. Got to spend a little time being precise taping the car up before hand asany paint that gets under it and on to the other half will show up whenyou spray over it later.... 1 inch tape around all the edges first.... and then with that done, roll out the paper and fill in the gaps.... quick once over with pre-cleaner, a swift wipe of the tac-rag, slopsome paint together, fire it into the gun, and splatter it out on to theshell, leaves it looking like this.... again handy having it on the spit for this part as you can turn it to anyangle to help getting all the nooks and crevices inside and underneath.... and when that was finished and dried the paper is whipped of andeverything that was sprayed is now taped off ready for the secondhalf to start.... the window and door jams are all taped from the inside so as toallow full coverage right out to the edges.... there is however one danger to watch out for whentaping a car up from the inside.... Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467566 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 5. Februar 2015 Autor #30 Meldung Teilen Geschrieben: 5. Februar 2015 with all that done the final thing was to hang some paper down fromthe sills of the car. This is not to avoid overspray on the underneathof the car, thankfully we're not quite that anal, but instead to stopand spray travelling under the car and landing on freshly paintedpanels the far side.... a wipe, tac, mix and splatter later.... with the shell now fully primered we could move attention to the otherbits, bumpers, doors, spoilers etc. However to do this the shell would haveto go outside to make room, and we were worried that extreme temperaturesof the Irish summer season might literally warp the metalwork!Yeah, as usuall it had been pissing rain solid for a week now.... alas, just as we were about to abandon work on the M and startbuilding an ark, the clouds broke and the sun shone through longenough to allow us to get this done. a few lengths of steel.... spit dismantled.... one short length of steel bolted to each spit stand... and some pimp daddy chain... allows us to hang the panels up for spraying like so.... and some string from the rafters hangs the spoiler and mirrors.(spoiler worked out grand like this, mirrors were a disaster,imagine trying to spray an old grandfather clock pendulum, whilst moving,and you'll get the picture, you live and you learn).... the rest of the stuff went on what ever we could find to prop them up... started to run out of suitable props at this stage so had to borrow theneighbours wheelie bin..... had to be careful with that and tape it up good and proper as he'salready fairly suspicious as to why the grass in his back gardenhas turned a funny shade of primer grey. bumper plugs are removed and done separately so as to allow theprimer under where they shall sit.... and thats it, the last of the stuff to be primered..... wipe, tac, mix, splatter and ta-daaaa.... join us tomorrow evening to find out how things turn out as wetake a turn to the darker side and start applying the Jet black. Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467567 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 5. Februar 2015 Autor #31 Meldung Teilen Geschrieben: 5. Februar 2015 (bearbeitet) We had decided right from the start of this project that the car wouldbe going out to have it's top coat applied by a professional. Thereasons for this were: a) i wanted the top coat and lacquer to be baked in anoven to get the finish as hard as possible. b) i wanted the finish to be fly free, ie. nothing stuck to theoutside of the shell but paint, no dust, no flies, no stray pigeons. c) perhaps most importantly of all I wanted it painted by aprofessional. We've sprayed quite a bit so far on this car and quitea few rally cars in the past and in a moment we'll also be spraying some blackto the interior and underneath of this one. But, there's a world of differencebetween spraying primer and spraying top coat. Spraying primer is fairlystraight forward and your always going to be sanding it before the nextcoating anyway so the finish doesn't have to be mint. But top coat can got*ts up in the blink of an eye if you haven't got enough experience to spotthe signs that all is not well. After this much effort to prep it, I want the topcoat to be as good as it can be and for that to happen it needs to bepainted by someone with a lot more experience than me. That said, I'll be f**ked if i'm going to let someone else have all the fun, wewere going to paint as much black as we could first.With the whole car now primered the bits we were going to paint blacknext would need to be sanded/ flattened. For the interior and boot weused these..... above is a 180 grit soft sanding block and below is a 220 gritsanding pad. They're much quicker to use than normal sheets ofwet and dry paper and they'd do just fine to give a quick lick to theinterior.... the engine bay was a different story though. I'd spent a lot of timealready sanding parts of the engine bay smooth and sanding downthe seam sealer flat as I wanted the bay to look as good as theoutside of the car. So now the primer in here was going to have to beguide coated and wet sanded with 600grit to get it mirror flat. Onlythe turrets, wheel tubs, chassis legs and front slam panel got thistreatment. Not bothering going this far on the bulkhead as it'll becovered by the oem soundproofing..... and with that eventually finished it was time to shoot a couple ofcoats of blackness.... very happy with how it came out, interior took it very well... the boot, as always,was a pure pig to do but came out well too.For anyone who's curious as to why a boot's a pig to spray, get yourselfan empty kellogs conflakes box, stick your head inside it and thenshove an aerosol can in there aswell and try to spray the inside of the box.You'll get the idea pretty quick. underside came out pretty sweet to.... and then the engine bay, would all that extra sanding pay off??? it looked like all that extra effort was worth while, the majority ofthe bay was silky smooth... all except that is, the f**king turret's and wheel tubs which was themain part I wanted to get right.... I'd like to say I took this discovery in a cool and collective manner,but the truth is passers by outside had to cover there young children'sears for quite some time. What had happened was we had sprayedthe underside of the car first and some overspray had blew up in tothe engine bay and settled on the turrets. Unawares of this we thenflipped the shell over and started spraying the engine bay. You couldsee it showing through as we were spraying but there wasn't a lot wecould do then, so we finished and let it dry to see what it would look like.... It's not terrible, but it's not what I wanted either. And the irony of it isit's only on the turrets and wheels tubs, the only part thats really noticablewhen everything refitted to the bay. So, what to do? well if you've readthis far you've probably a good idea. After leaving the paint to fullycure the effected areas were wet sanded back down again with 600grit.Didn't have to go right back to the primer to get it flat although the areasdo look grey in the pictures... each side was sanded back to a line or crease in the bodyworkas it was going to have to be taped off to be resprayed andyou don't want nasty tape/paint lines standing out..... So to also help blend in the resprayed parts, instead of just normallytaping off the area, the masking tape was rolled like so.... and then placed snug up against the seam.... and another strip of tape softly over it to stop the roll unfurling.... and repeat until all the area is done.... the thinking behind this is that if you just taped it normally you'd geta noticeable line where the paint builds up against the edge of thetape, whereas this way some of the paint will fade in under the rolland if all goes well, make the line unnoticeable.With that done the rest of the shell needed to be taped up.... and then mix a small bit of paint, spray it on, say 3 decades of the rosaryand slowly open one eye to see if it's come up good.... yipidy f u c k i n g doda.... Bearbeitet: 5. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467569 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 5. Februar 2015 Autor #32 Meldung Teilen Geschrieben: 5. Februar 2015 with that little episode over it was time to move on to the finalpreparation of the exterior and remaining panels for top coat.The reason this wasn't sanded along with the interior is if anyoverspray crept through the masking you could end up 15 picturesback up again and in serious need of sedation. Quick mask upto stop the nice black paintwork getting messed up by the comingwet sanding.... and then head to toe every last square inch of bodywork left inprimer gets powder guide coated and wet sanded with 600grit wetand dry paper.... no scratches or blemishes to worry about this time just the need toget the primer as mirror flat as possible, any top coat can only beas flat as whats underneath it.... bit of washing up liquid in the water helps the sanding go a little easierand cleans any stray contaminants off the panels as you go... this.... took... forever.... and... a day... or 3 weeks to be precise.... but there is a small reward, with everything sanded so smoothyou could now catch the light and see reflections on the panelsand see how flat it'll look when black.... and then with nothing left to do, the time had finally come for thetop coat to go on. How was the black going to look? Would itcome out ok? Was all this effort going to pay off?..... And i'd dearly love to be able to tell you all, but the simple truth is,we just delivered the shell to the bodyshop this morning and it'll bean agonising few weeks before we get to see the finished article. But at least now you know how I feel..... STAY TUNED Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467571 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 5. Februar 2015 Autor #33 Meldung Teilen Geschrieben: 5. Februar 2015 Evening all, No big load of verbal diaorea this post, will let the pic's do thetalking. All the bits are back from paint and although it makes nosense what so ever to assemble it now, as theres still a load ofwork to do on the bare shell, I'm not waiting another 5 monthsto get a look at this thing together. It's been about 13/14 months of bodypreperation getting this thing to paint and the big question wasalways going to be, was it worth it?....In a word,Yes Next up is to get it all assunder again without scratching itand start the cavity waxing and sound proofing. STAY TUNED Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1467574 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 11. Februar 2015 Autor #34 Meldung Teilen Geschrieben: 11. Februar 2015 (bearbeitet) Evening all, After stripping the removable panels back off the car again and packing them away safely it was on to the next task. Sound deadening. That sticky black crap thats a ball breaker to get off when your stripping a car down. Still, going back on should be a walk in the park, he said, stupidly. Back at the start of the rebuild I'd thought a bit about this and had looked into the price and availability of aftermarket products, i.e. Fatmat and Dynamat, and had considered covering the whole floor pan to make the inside as quiet as possible. Then I got a chance to see a sheet of Dynamat in person, and it struck me, this stuff's heavy. If I cover the whole floorpan with this I'm going to be adding a fair bit of weight to the car. And on further reflection I don't actually remember thinking at any stage "sweet jesus this car's a bit noisey in here." So I decided I'd replicate the original sound proofing instead, as someone who almost certainly knows a lot more about this than me, had sat down in the beginning when this car was being designed and decided exactly how much was needed and where it should go. Plus, a part number search shows the e30's sound proofing material is still used in all the modern bmw fleet, so it must be half decent? With that decided next thing to do was search through the pictures I'd taken on disassembly and any other pic's I could find online to make paper templates of the original shapes. Which came out like this.... I added in a couple of small extra bits, one either side on the rear inner wheel arches to help keep down any extra drone from running wider than standard rear tyres.... and a little bit at the bottom of each speaker pot.... then I ordered up some soundproofing from Bmw. Originally I'd intended to get 12 of the 50cm X 50cm sheets to do it all, but upon making the order I was informed that that part number had been superseded with another part number (pn.51488165271), and the new one was twice the price. So, I assumed the sheets were probably twice the size and to be on the safe side went ahead and ordered 7. Imagine my suprise when I went to collect it and found I now had enough to sound proof the starship f*cking enterprise! The sheets are a little over 3 times the size of the original part number. On the bright side I could now cut all the sheets out fully without having to join bit's together.... I've seen other pic's on the net of sound proofing and it looked soft and easy to trim, god only knows what I've ended up with, cause this stuff's as ridgid as a plank and brittle too. So, templates marked out.... ruler and stanley knife to cut out the straight pieces... and for curved bits a little heat from a heat gun softens it just nicely for cutting with a scissors.... With all the bits cut out, next up was to get the body work ready for them, a quick clean with thinners gets the surface clean of the little spots of buffing compound scattered throughout the inside of the shell.... and then lay the sheet in place, see what I mean about rigid.... So, a little help from the heat gun.... and the stuff falls down neatly in to place, but it isn't stuck on yet.... For that it needs to be heated up a little more. Which brings out the gas blow lamp.... and a little hardware store roller to press it down evenly..... a little practice shows that just enough heat at the surface of the sheet to turn it a wet shade of dark black allows the underside to get a good solid bond.... heat gunned.... blow lamped.... Next up was another small job to tick off the "things to do encyclopaedia". The roof band that covers the join at the rear roof extension.... first up was to fit the 2 little sealing strips to the little recesses on the underside of the band.... I spent 20 minutes poking in the first one. before realising on the second one that they could slide straight in from the end, in 5 seconds. I know, i know, it's a miracle I've made it this far..... new clips popped in to the roof.... and sledge hammer the roof band down on to them... There's one large rivet to go in either side of the band to finish it off which I've yet to do. Bearbeitet: 11. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1471647 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 11. Februar 2015 Autor #35 Meldung Teilen Geschrieben: 11. Februar 2015 (bearbeitet) (Die Bilder dieses Posts sind nicht vorhanden, vollständigkeitshalber poste ichs trotzdem) After all that, it's on to the next job on the list, cavity waxing. All the box sections and cavities need a coating of wax as the acid dipping had removed all the original stuff. This can be a bit of a messy job and if you get this wax on the outside paintwork you'll need to use white spirits to remove it. A situation thats worth trying to avoid you'll agree. So, some soft sheets and some masking tape.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1489.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1487.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1488.jpg The experienced one's among you will figure out why it's far less grief just to go out and buy some new sheets rather than borrowing what you were sure was "old and no longer needed sheets". Anywho, with the shell rapped up, first up was to glue on the new roof insulation.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1491.jpg again the spit helps greatly with this job..... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1492.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1493.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1494.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1495.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1497.jpg Then we have the cavity wax, I went with Dinitrol..... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1498.jpg it comes in 1 litre "shultz" type tins and you need a "shultz" style gun to screw on to the top of the can for spraying it.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1499.jpg the gun itself comes with a normal type spay nozzle which is useful for spraying open areas, also need though is a "wand". This is a 2 foot piece of plastic tubing that screws into the gun one end, and the other end has a jet with multiple holes to spray it out in all directions, which is perfect for inside the box sections..... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1500.jpg all rigged up and ready to go, the tin of wax is dipped in a bucket of hot water for a while first. This thin's out the wax and makes it spray out in a finer mist giving better coverage.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1504.jpg For the actual application itself I just picked one area at a time, picked out a few holes along that section that would allow the wand to fit in and spray the full length and then taped off every other hole on that section. The tape is used for two reasons, the first and obvious one is you don't end up looking like a wax candle at the end of the day from overspray leaking out, and the second is after you've sprayed that section you can peal off the bits of tape to see if they've a good coating of wax on the underside, so you know you've got 100% coverage along the whole length inside..... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1505.jpg No wax on any of the bits of tape and you've missed a bit..... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1506.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1508.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1509.jpg probably the trickiest piece to do was this section.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1525.jpg it has more bloody holes in it than a fishing net.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1527.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1528.jpg took a lot longer to tape up than actually wax.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1529.jpg bit hard to tell from the pic, but this is actually the area under the scuttle panel out where the wiper motor lives. Everybody knows how these cars like to rust in here so it got a heavy coating of wax.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1538.jpg inside the roof pillars and skeleton got a good coating.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1541.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1540.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1547.jpg Out of the whole car I only had to drill two holes to get access to an area to coat it and it was this little box section. Bit hard to picture it, but its part of the rear chassis leg box section. The hole at the front is where the rear subframe mounts up to and at the rear of the pic is the back spring platform. The last decent hole to get the wand into was off nearer the back of the car and the wand just wouldn't reach all the way up to this bit..... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1518.jpg on the inside of the box section there was no joy either, there were holes but they were too small for the wand to fit. So picked a hole in the middle of the section each side.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1517.jpg and drilled it out large enough to fit the wand.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1519.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1520.jpg With most of the box sections done we could move on to some of the larger open areas needing wax. This is the area under the rear side window, bit hard to figure from the pic I know, but the metal in the top in the pic is the inside of the rear quarter panel.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1511.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1515.jpg and the back half, thats the front of the rear inner wheel arch on the right.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1510.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1514.jpg There's quite a bit to wax overall in the shell and it took two full days till I was happy I'd got everywhere. The other thing thats handy to know is that if you are leaving the gun for a few hours or over night the wax will dry out and clog it up. So, a little aerosol lid full of thinners or white spirits run through the gun cleans it out spotless... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1559.jpg after the shell waxing was finished the last of the internal sound insulation could be fitted.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1549.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1607.jpg and then the final bits, the two front doors.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1550.jpg sound deadening first.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1552.jpg and then wax.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1555.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1554.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1556.jpg http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1558.jpg All in all we got through just about five tins of the stuff.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1562.jpg and then the fun really started, where the hell do all these go again.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1563.jpg And thats about where we're up to at the moment. Next up, taking a break from the shell for a while and starting on the driveline. First up for overhaul will be a differential thats looks like it went down with the Titanic.... http://www.xworksmotorsport.com/m3%20build%20%2810%29/m3-1572.jpg till next time.... Bearbeitet: 11. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1471648 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 11. Februar 2015 Autor #36 Meldung Teilen Geschrieben: 11. Februar 2015 (bearbeitet) Evenin all, Thanks again for the kind words, much appreciated. As mentioned in the last post we're taking a break from the shell for a while and moving on to the drive train overhaul, and, starting at the back and moving forward, first up we have the differential. That magical lump of metal that sits in the back axle and lets you move in a sideways fashion when the opportunity arises. First and foremost, as usual, we'll just take a second to say the obvious, this isn't a guide on how to build a diff, for that, go here http://bmw.ctcms.net/BMW/Software/E3...0Bmw%20e30.rar (password to unzip the files is bmwfaq ) download the full workshop manual and follow the smart people at Bmw's guide, The section on the diff starts at 33-101. Unfortunately they don't use a large selection of hammers to do their overhaul, so I have trouble relating to it. Anywho, back to my diff. This is a medium case diff as identified by the 8 bolts that hold on the back cover, the small case diff has 6 bolts holding on the rear cover and the large case diff is easily identified by snapping your spine while trying to lift it as it weighs 14 ton. First up pop the 8 bolts off the rear cover and remove, spilling the remaining horrible smelling diff oil over your clean bench..... then using special tool no. 959bigbar, we popped out the halfshaft flanges.... in the middle of the diff that big gear you can see is the crownwheel and to the right of it is the limited slip differential....... and next up was the crownwheel bearing cups. One on each side of the diff and these house the crownwheel bearing outer races which hold the diff unit in place. Theres a ring of six bolts that hold each one in place, and before you undo them it pays to take a second to notice that each cup has a square notch on top of them (as arrowed) which alligns with a corresponding notch on the diff casing (as arrowed).... When you undo the ring of bolts and pull out the cups the diff unit will drop inside, so you can either let it drop and damage it or put your hand under it and damage it instead. If your lucky enough to have an assistant helping you then you'll not need me to tell you who's hand to use. When you pull the cups you'll notice a shim (arrowed), this will either be still stuck to the casing or the cup. Keep these shims matched with the cup they were fitted with and mark which side they came off, they'll need to go back on the same side or things will start to get funky. When the cup's off you can see why it has a notch to show you why it needs to be fitted this way up. In the pic bellow you can see the cup has an oil drilling (arrowed) which lets oil splash in the top of the cup and drip down on to the crownwheel bearings, and obviously if you fit the cup any other way the oil aint going to drip anywhere.... With the crownwheel/diff unit carefully lifted out all thats left in the casing is the pinion...... to remove this you gotta take the pinion flange off the front of the pinion.... first up bend back in the little piece of the locking washer from the recess to let the nut loosen..... and then use special tool part no.959rustypieceofbar.... which is basically a piece of bar with holes drilled into it to allow 2 M8 bolts to fit through it and bolt up to the pinion flange and hold it from turning while loosening the nut.... once the nut's off, the flange should lift off, if it doesn't smack it repeatedly with a large hammer while searing at it loudly..... pop the nut back on to protect the threads from stray hammer blows, it turns out fine threads and large hammers do not mix, I know, it suprised me too.... pry out the pinion seal..... and then strap on a pullers and push out the pinion..... (I know the pullers is crooked, if it really bothers you, tilt your head to the side) and bingo, one pinion and a front and rear pinion bearing and although its hard to make out in this pic, also a collapsible spacer .... If your diff has started to whine, rumble or make strange noises then usually it's these bearings that have started to sh*t themselves. Everytime you drop the hammer in your car and unleash all that horsepower it's this pinion gear that try's to burst it's way out of the differential casing and these two bearings that have to persuade it to stay. next up is to strip out the bearing outer races starting with the pinion pair in the diff casing. The inner pinion bearing race drives out down into the casing and flip it over and the outer race drives out through the top... the two races out and the next thing to make a mental note of, is the inside race has a shim between it and it's seat in the casing(arrowed). This has to go back in to the same spot upon reassembly or again things will get funky.... next up the crownwheel cups, drive the oil seals outwards..... and flip it over and drive the bearing races out.... With everything stripped down it's time for clean up. As you can see below the casing was covered in a fine blend of crap and rust..... So we break out the "de-scaler", as usual I've no idea what the rest of the world calls this tool. It's air operated and when you pull the trigger all them little needles plunge up and down pounding the crap out of whatever you happen to be holding it against. It does a fine job of removing all the loose crap and rust from the casing and then proceeds to evenly spread it around the rest of the garage while deafening you in the process..... casing cleaned, it gets a coating of red oxide, before a final coating of satin black.... the rear cover (which I think is a Z3 item with the extra cooling fins) gets a steam clean. One bit that gets a little special attention is the little breather hole. Gotta make sure this ain't clogged up, as if it is, when inside the diff gets hot theres no where for the expanding warm air to get out and it ends up pushing oil out past your lovely new seals... after that it's on to pulling off the crownwheel bearings, these little fu*kers were tight and needed the use of the bigger pullers.... the other little thing to be careful of is the thin trigger wheel shown below pressed on to the diff unit. Its the trigger wheel that the speedo sender reads to tell the speedo gauge up on the dash how far over the speed limit your going. As it's thin, it'll bend easily and if your unlucky you'll reassemble everything only to find out your speedo no longer works, which will mean stripping everything back down again and repairing or replacing it, which is nice..... after that, it was on to pulling the pinion inner bearing. To say this was tight really doesn't convey it accurately, b*stard tight would be a better discription. One of those one's where you strap the pullers on and start winding, and winding, and winding, and then stop, and rap rags around the bearing in the misguided thought that if the bearing explodes they'll save you from harm, while the truth being that if it does go you'll now have bits of dirty rag stuck in you along with bits of bearing.... and eventually theres a large crack and after you check for shrapnel wounds you realise the bearing has started to come. (mental note, must look into health insurance.) Then with everything stripped down it's on to the "decontamination unit".... Two basins of paraffin, one to wash the heavy crap off and the second to rinse the smaller stuff off and then finally aerosol cans of parts cleaner to give them the final rinse. Bearbeitet: 11. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1471649 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 11. Februar 2015 Autor #37 Meldung Teilen Geschrieben: 11. Februar 2015 (bearbeitet) (Dieser Bilder dieses Posts sind ebenfalls nicht vorhanden) With that done it's on to setting up a clean area to place the parts on once their washed..... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1611.jpg Below is a picture of everything and a list of what we've chosen to replace..... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1610.jpg (blue font is the changed parts)1. Pinion flange2. Pinion3.Pinion nut lock ring (oe) 23 21 1 490 1204. Pinion nut5. Collapsible pinion spacer (oe) 33 12 1 744 3686. Pinion seal (oe) 33 10 1 214 0997. Pinion shim8. Pinion inner bearing (aftermarket) outer race- SKF fk-hm 89410-2-cl7a bearing- SKF ak-hm 89449-2-cl7a9. Pinion outer bearing outer race (aftermarket) SKF fk-h 88510-2-cl7a10. Pinion outer bearing (aftermarket) SKF ck-hm 88542-2-cl7a11. Crownwheel bearing cup shim12. Crownwheel bearing cup O ring (x2) (oe) 33 11 1 214 14413. Halfshaft flange14 Crownwheel bearing cup15. Crownwheel bearings (x2) (aftermarket)outer race- SKF fk-lm 503310bearing- SKF k-lm 503349-cl7a16. Halfshaft flange seals (x2) (oe) 33 10 7 505 602 (comes with part 17's included)17. Halfshaft lock rings (x2) (oe) (comes with above)18. Limited slip differential and crownwheel19. Casing19. Casing gasket (oe) 33 11 1 210 40520. Speedo sender locking plate21. Speedo sendo and O ring22. Z3 rear cover In the list above the renewed parts listed in blue are marked(oe) for bought off BMW, and (aftermarket) were sourced at a local bearing supplier. The bearings sourced "aftermarket"are either SKF or KLM bearings which is exactly what you'll get from Bmw, only they won't come in a nice little Bmw jiffeybag, but they will cost less than half the main dealer price. With everything together it was time for reassembly. I've takenthe decission not to open up the limited slip diff unit as before the car came off the road it was working perfect, and I know if I open it I'll start replacing things, and, well, that money canbe better spent elsewhere. Beer. First up on the list of reassembly is to press on the crownwheel bearings..... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1612.jpg http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1613.jpg then fit the races for these bearing into the crownwheel cups.... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1614.jpg flip the cup over and pop in the halfshaft seals. The seal goes in tillit butt's up against the back of the bearing race(arrowed).... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1615.jpg One thing to be careful of is when driving in the seal up against the back of the bearing race, is, if you go a little tofar you can possibly knock the bearing race back out a bit. So, when done the cup is flipped over again and the race is tapped back in again to make sure it's home. http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1616.jpg Then on to the pinion bearing races. First up the inner bearing race.This was the one that had the shim under it, so, shim dropped infirst and then bearing race popped in on top of it.... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1617.jpg http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1621.jpg then flipped over and the outer race fitted.... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1620.jpg With all the races refitted the next thing to be done is pop back inthe diff unit and refit the cups and shims(arrowed) remembering to keep them to the sides they originally came out of.... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1623.jpg with the cups bolted back in tight both sides it's time for the first setup check. The cups should now be holding the diff unit tightly,it should be able to rotate but have no noticeable play in the directionof the arrows below.... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_1622.jpg and aswell as having no play the cups should also be slightly squeezing the diff bearings which is known as preload. This preload is measuredby a special tool which basically bolts on to the halfshaft flange andmeasures how much effort it takes to rotate the crownwheel. To littleforce, remove some shims which tightens up the preload on the bearingswhen the cups are refitted. To much force required to turn it and you pop in the next size up shim to ease off the preload.There is figures given for it in the workshop manual.If all you've changed in the overhaul is bearings and everything else isoriginal to that casing going back together then odds are the shims that were there already will be fairly spot on.If you've built a lot of diff's there's another special tool you can use tomeasure the preload.... http://www.xworksmotorsport.com/m3%20build%20%2811%29/m3_hand.jpg (Ab hier fängt ein neuer Post an) (continued from previous page)With all that done, we pop the crownwheel and cups back off again,and start fitting up the pinion. First up drop in the outer pinion bearing..... followed by the seal..... and then the inner pinion bearing is pressed on to the pinion shaftand then the colapsable spacer(arrowed) is dropped on as well..... this lot is then pressed into the casing and up through the outer bearing. The pinion flange is popped back on and special tool reattached..... and the pinion nut is retightened..... Theres no torque for this nut as again your using it to "preload" orsqueeze the two bearings below it just the right amount.When retightening it you can feel the nut first tighten a little bit as the outer bearing gets squashed up against the collapseable spacer,but the pinion still is able to slap up and down in the direction below.... What has happened here is the both bearings have not been squeezedclose enough together yet and they can lift up and down off their racesbecause that collapsible spacer is keeping them apart. So, the nut is tightened down more, slowley, crushing the collapsiblespacer till theres no up and down play and the bearings are sitting snugly in their seats and then ever so slightly tightened again in little steps till the right preload is got on the bearings. This extra bit of squash (preload)on the bearings is done because when you nail the accelerator pedalif the bearings were just fitted loosely they'd start to lift out of theirraces and the pinion would start it's break for glory out through the diff casing. Instead of leaving two nice big black tyre marks you endup leaving one nice big trail of diff oil and gears.Again there is a special tool for measuring the correct preload and the figures for it are in the manual. With everything tightened up correctly and a quick splash of holy water, the lock washer is bent in to place.... casing is flipped over and crownwheel unit and cups refitted.... and halfshaft flanges refitted.... And then finally on to the most important check of the lot, tooth contact. Some engineers blue.... spread evenly on 3 crownwheel teeth..... and then rotate the diff gears by turning the front pinion flange while putting a bit of loading on it by holding one of the output flanges loosely.... and what your left with should be a marking on the crownwheel teethof where the pinion teeth are contacting it. What your looking for is a nice fat contact patch in the middle of the tooth, something like below.... If the contact patch is too high up towards the tip off the tooth you'll needto move the pinion gear closer to the crownwheel by putting a fatter shim under the inner pinion bearing.And if it's too low to the base of the tooth you'll need to fit a thinner shimto move the pinion gear back away from the crownwheel.If the contact patch is too far towards the inside of the crownwheel tooththen you've got to change the crownwheel bearing cup shims to move the crownwheel away from the pinion gear.And likewise if the contact patch is towards the outside of the toothchange the cup shims to move the crownwheel towards the pinion gear.Again if none of the main components have changed during the overhaulthen the contact patch should be pretty close to right, but you stillgotta check. If you get the tooth contact patch badly wrong, then don'tworry to much about it, you'll be getting a chance to rebuild it all againafter a few miles, when it sh*ts itself. After all that mind numbing crap is done, a bit of gasket sealer.... under the gasket and a little smear above.... bolt the rear cover back on.... pop the speedo sender back in with a fresh o ring.... bungs back in and fill with oil and thats it.... and all that waffle was for a case with 2 gears and 4 bearings,I'm buying a new keyboard for whats coming next..... till next time.... Bearbeitet: 11. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1471650 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 11. Februar 2015 Autor #38 Meldung Teilen Geschrieben: 11. Februar 2015 (bearbeitet) Evenin all, Bit of a gap since the last update, was so busy working on the carI couldn't get time to write up all the work. Managed to get a lotdone since the last update. And when you run that through the "Babelfish Bullsh*t Translator" it comes outas: Ages since the last update cause the shed feels like the inside of a freezerat this time of year and everything you pick up brings frostbite a step closer.The heater heats itself and nothing else and the camera took on a life of its ownand decided to mix up all the photos for the crack. So heres what actually got done.The driveshaft.... despite looking their age both joints on the shaft still rotate in all directionswithout any sticking or tightness, so a clean up and they're good to go..... what is getting changed is the centre bearing. Before splitting the shafta quick check for the original marks to help align it correctly when goingback together. If they're gone, two small dabs of tipex will do..... collar screwed back off the shaft and splines slid apart..... a slice around the rubber allows the outer piece of carrier bearingto be cut away (along with tops of fingers)..... pop the circlip and the large washer behind it off.... and then simply pull the bearing off the shaft with the pullers.... which is how it goes in the fantasy world of "workshop manual land".However in the real world no amount of pulling, beating or swearingwould remove the bearing. So the special bearing removing tool hadto be used, also known as an angle grinder..... shaft gets a quick lick of sandpaper to clean up where the newbearing is going to sit.... the new carrier bearing has the bearing recessed on one side like so...... and flush on the other side like so..... the bearing in the centre is heated up using the heat gun.... which allows it to slide up on to the shaft easily, with the recessedside facing in and the flush side facing out like so..... then the washer and circlip go back on and if you've fitted thebearing the wrong way around you now realise the cirlip won'treach in to fit in it's groove anymore, which will mean the whole thing hasto come off again to be flipped around, which is nice...... then the threaded cup is slid back up on to the splines, some coppergrease on the splines and then the other half of the shaft is slid backon with the white marks aligned.... The threaded cup isn't tightened up to lock the shaft length till it'sall refitted back on the car and extended to the correct length.... The last thing to do then was rebolt the rubber "guibo"or donut onto the gearbox end of the shaft. Mine was ingood nick as i'd only replaced it a while back. Unfortunatelyshortly after replacing it I read about the E34 M5 one(p/n 26 11 2 226 527) being a straight forward replacement,only its alot thicker and as such most probably longer lasting,(f*ck it anyway)...... STAY TUNED Bearbeitet: 11. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1471652 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 13. Februar 2015 Autor #39 Meldung Teilen Geschrieben: 13. Februar 2015 (bearbeitet) With the driveshaft out of the way, there was no avoiding it any longer, next up was going to be the big aluminium box full of gears. First thing to note is, the following waffle is all about the Getrag 265/5 dogleg gearbox. The bit thats worth noting about that, is, the 265/5 gearbox is the dog leg gearbox, meaning that 1st is all the way over to the left and down (under reverse). The Getrag 265/6 which was also fitted to M3's (mostly American versions I think) is the non dog leg 5 speed overdrive gearbox. It pays to make a mental note of the difference between a 265/5 and a 265/6 cause when your looking up parts on real.oem or looking up the manual for torques or proceedures theres a difference between the two internally. And its frustrating ordering in parts for your box only to find upon collection that the bits you've ordered are for the wrong one and are non refundable. (And despite trying, no amount of hammering will make them fit) On to the actual disassembly of the box. This is a very complicated proceedure, and I'm now going to attempt to explain the highly skilled, meticulous, disassembly of my gearbox. Measure in exactly 253 mm from the rear output flange and up 176mm from the bottom of the casing on the left hand side and mark this spot with a large red x..... Then hit this spot an unmercyfull wallop with special tool part no. 959sledgehammer..... and ta-daaaa...... For anyone who's not comfortable using the sledge hammer method of disassembly, the the full strip down procedure is given here in the Bmw workshop manual.... http://www.bmwtechinfo.com/repair/main/421en/index.htm click the link, click on the "contents" box, click on "23 manual transmission" and then make sure you click on the right gearbox 265/5 or 265/6. With the gearbox assunder it can help a little to know how all this crap in here is supposed to work. If for no other resason just so you can easily identify what part of the rebuild has gone t*ts up. WARNING: You will most likely know less about the workings of a gearbox after reading my explanation than before reading it. Inside the gearbox casing theres 3 main shafts..... [imghttp://e30-talk.com/uploads/images/minor_rust/image835.jpg[/img] Theres one or two cogs missing from the above picture but its enough to get the idea. Pictured are the 3 shafts, the input, output and layshaft. The first thing thats makes fuck all sense, at first, is how is the top shaft in the picture is in fact two shafts (input shaft & output shaft)? The input shaft as seen below is short and only has one gear and one bearing on it, and in the end of the input shaft is a hole with a small roller bearing in it which allows the other shaft, the output shaft, to sit into it and be supported...... new bearing in the hole, old one out on the bench.... The whole idea behind this setup is that the two shafts can move at different speeds to each other. The input shaft at the front of the box is connected through your clutch to the engine flywheel. So, with the clutch let out this shaft is always spinning at engine speed. The whole aim of the game is to pass this drive through a series of gears to reduce the revs coming out the back of the box. 1st gear reducing it the most, working right up to 5th gear which in this box is 1:1 ie one turn in = one turn out. And heres the selection of gears it uses to do this...... (1st and reverse are missing from right of pic) With the input shaft spinning the one gear thats solidly connected to this (5th gear) is also spinning.... and because 5th gear on the input shaft is also connected to 5th gear on the layshaft (underneath it) then the whole layshaft is also spinning too. And because basically the layshaft is one big solid lump of metal, then all the other gears it's in contact with are spinning too. So, gearbox in neutral, engine turning over, all thats marked red is spinning at engine speed.... So how the fu*k is the output shaft coming out the back of the box not spinning if all the gears on it are spinning?...... The answer is all the gears on the output shaft (top shaft), while sitting on it, are not actually connected to it. Between the centre of the gears and and the shaft are little roller bearings, so no matter how fast you turn the gears you wont turn the shaft..... So to get the output shaft to turn you have to "lock" one of these gears to the shaft and to do this you use the syncro hubs..... The syncro hubs sit in between the gears and have two main pieces. The centre of the syncro hub is connected solidly to the output shaft by splines (red bit in pic below) and the outside part (blue bit) is also splined onto the red bit, the only difference being the blue piece can slide over and back on the red piece..... The reason it can slide over and back is so it can lock on to these little teeth on the side's of the main gears (red piece below) while also staying connected to the centre of the syncro hub......... So when the blue piece of the syncro hub slides over to grab these red teeth in the pic below it's also still connected to the centre piece of the syncro hub, and bingo, you've just locked one of the gears to the output shaft. Now the output shaft is being driven...... In the pic below the red syncro hub is slid to the left and the gear to the left of it (3rd gear) is "engaged" and locked to the output shaft, hence the output shaft (To Differential) is now been driven by the engine..... The other bit in here thats important is the syncro ring..... It sits in between the gear and the syncrohub and it has the shittiest job of the lot. When the syncro hub moves over to grab them little teeth on the side of the gear and lock it on to the shaft it runs into a little problem. The hub and the gear are rotating at different speeds. So if one tries to mesh with the other like this then theres going to be a horrible sound in the gearbox and a whole lot of new little bits stuck to that drain bung magnet. What needs to happen is the two need to be rotating at the same speed so they can lock together. This is where the syncro ring comes in. The inside of the syncro ring is cone shaped..... and the bit of the gear it slides on to is also cone shaped..... so as the syncro hub sleeve moves across it grabs the brass syncro ring first and then squeezes this up against the gear to get it rotating at the same speed and then as they synchronize it can then slide fully across and lock onto the gear...... And then at last, the final bit, for anyone left that hasn't got bored and logged out to go look for porn sites. How does moving one simple gear lever from up in the drivers seat move all these syncro hubs down in the gearbox? The box has 6 gears, 1st 2nd 3rd 4th 5th and reverse that can be selected. Each syncro hub can slide forward or back to select the gear in front of it or behind it, so thats 3 syncro hubs that need to moved. A brass "selector fork" sits on to each one of these syncro hubs.... and these 3 selector forks are solidly connected to 3 rods.... (only 2 forks in picture) Theres also another rod in there too, its the "selector rod" and its the only one thats connected to your gearlever. When you move your gearlever right it rotates right, move your gearlever left it rotates left..... attached to this "selector rod" (the funky green one) is a finger (also funky green). And as mentioned when you move the gearlever left and right when in neutral the green rod rotates left and right moving this green finger up and down between the 3 selector fork rods (funky purple, blue and yellow)......... move the gearlever all the way to the right, the selector rod rotates all the way to the right and the finger moves all the way up to engauge with a cut out in the purple rod. Now when you move the gear lever back or forward in to 4th or 5th gear position the green finger moves the purple rod backwards or forwards, which in turn moves the purple fork which moves the syncro hub forward to engage 5th gear or backwards to engauge 4th..... Leave the gear lever in the middle position and move it backwards or forwards between 2nd and 3rd gear position and the green finger hooks up with the blue shaft and fork moving the 2nd/3rd syncro hub locking in either 2nd or 3rd gear..... and finally move the lever all the way to the left over for reverse and first, the green finger gets rotated all the way down to hook up with the yellow shaft and either select 1st or reverse down the back of the box...... And thats roughly how it all works, I think, maybe. The main reason for pulling the box asunder was I wanted to replace the bearings in there. A couple of months before pulling the car off the road a nasty clicking sound came into the front end of the gearbox, so we pulled the box and stripped off the front casing to try and find the culprit before the clicking progressed to a knocking and finally the big "boom". The front input shaft bearing looked ok, a little bit gritty when spun but not the cause of the noise.... and then we went on to the one under it, the front layshaft bearing. We had a sneaky feeling this could have been the cause of the noise. Call it a sixth sense if you will but there was something bugging us about this bearing. Here's the two of them side by side, it takes a sharp eye to spot the difference, but if you look close enough you should be able to see the tiny defect..... Yeah, the bearing cage had completely shit itself, allowing the balls to move around as they pleased, which had resulted in the clicking sound. The cage that holds the balls spaced out is made out of a hard plastic type stuff (*might not be correct technical term). And the reason it had broken up was the inner race of the bearing had started to pit, and got worse over time, which meant the little balls were bouncing over the pothole created...... Eventually it got to hard for the plastic cage to hold on to the balls as they bounced and it broke up. Next up had the box been kept driven would probably have been one of the balls getting jammed or popping out of the bearing, either of which would probably have resulted in a nice little explosion of bits inside the box. Thankfully due to that clicking sound we got a little warning that the end was coming. At the time we only replaced the front end bearings because the car is my everyday car and I needed it back on the road as soon as possible. So now it's all coming asunder and all the 5 main bearing in the box are getting changed..... Number 4 and 5 in the pic above are on either ends of the layshaft (bottom shaft) and are just normal bearings available aftermarket. The front layshaft bearing (on left in pic) 25x62x17mm was replaced with a Timken bearing p/n 6305/C3. The rear one (on right) 72x30x19mm was replaced with a SKF bearing p/n 6306/C3.... Number 3, the rear bearing on the output shaft is identical to the number 5 the layshaft rear bearing, and again was replaced with a SKF bearing p/n 6306/C3..... So that just left us with number 1 and 2 to source. I could only get these from the main dealer as they're a bit odd ball bearings. The first one (number 1 bmw p/n 23121204580 ) the input shaft bearing is special because it has a groove cut into the outside race to take a circlip as seen below...... This must be made from rare minerals as thats the only reason I can see why it cost 80 something euro! But if that one was made from rare minerals then they must have to travel all the way to the moon to get the stuff to make bearing number 2 (bmw p/n 23231205191). This is a 2 piece needle roller bearing and it weighs in at 208 euro. That hurt..... http://www.xworksmotorsport.com/m3%20build%20%2813%29/m3_1949.jpg With all the main bearings done it was time to move on to the smaller ones. The red arrowed one below was changed because it has one of them hard plastic races holding it together and these get brittle over time.... bmw p/n 23221207784....... all the blue arrowed ones are the little double row needle roller bearings that fit inside the gears. These were available after market but had a 4 week order in time so I just got them from the main dealer instead (bmw p/n 23221228279)...... Only 2 of them little needle roller bearings ride on the shaft, the rest of them ride on their own little separate inner race's pictured below. None of these needed replacing as there was no marks on them and they showed no signs of wear..... The other thing that I wanted to pay special attention to while in here was the syncro rings. 1st gear had a habit of being awkward to select in this box in stop go traffic, especially when warm. So all the syncro's got checked while assunder..... to check them the syncro ring is placed on top of it's gear, lightly pressed down and the gap (arrowed below) measured with feeler blades..... for a new syncro ring sitting on a gear the gap is 1.0 to 1.3mm if the gap on the old one is below 0.8mm she kaput. The only difference is reverse gear, 0.5-0.6 new less than 0.4mm replace. Given I couldn't fit a fly's pubic hair bewteen my 1st gear syncro ring and the gear I could safely say it was fu*ked... One of the other things that got checked was the shift forks. These sit into the groove on the syncro hubs and push them backwards and forwards. As the syncro hubs are allways spinning and the fork are allways held still, the side faces of the forks can tend to wear, giving a slopply gear change (you have to move the gear lever move before a worn fork actually starts to move the syncro hub)...... minimum fork thickness is 4.8mm, thankfully mine were all good to go..... With everything cleaned, checked and replaced if worn, it was time to try and figure out how it all went back together. Starting with the rear casing...... and this little collection of bits whose job it is to spring load the gear lever when your moving it from side to side in neutral.... smaller of the two springs dropped in like so..... flat washer and circlip on top, to stop it wandering.... and then this little tube whose job it is to grab the selector rod.... as you can see the tube has a specially cut internal section which allows the selector rod to side back and forth inside it undisturbed, but when the selector rod is rotated left or right (when you move the gear lever left or right) it rotates the whole tube left or right...... the selector rod is kept free during all this movement thanks to 4 little rollers stuck on the shaft (one hidden underneath).... the tube sits into the casing like so..... making sure the leg attached to the tube is the right side of that first spring that was fitted..... the second bigger spring goes on next, the legs of which sit like below...... followed by a washer and circlip..... next up is the method of stopping the gear lever from being pushed to far to the left or right. The little tube just fitted has an elongated notch cut into it like so...... and when in place this notch lines up inside with this hole on the casing..... into which is screwed this little locater bolt.... before screwing it in, its given a dab of loctite to lock it in place but also to seal it so gearbox oil can't weep out..... when it's in theres the head of the bolt and the casing has been drilled for lockwire..... so some lockwire is fitted.... when all that crap is fitted this next little selection of stuff is hammered in, in this order.... into this hole.... this little plunger gives you that extra bit of spring force to overcome when your pushing the gearlever all the way over for reverse. A little bit of gasket sealer on the sides of the black plug below on fitment helps keep it oil tight..... After that it's onto the centre casing and the fitment of the worlds most expensive gearbox bearing. Only fitting the outside piece of this at the moment, the inner ring will be used later.... the aluminium casing around the bearing hole in the centre of the casing is given a nice heating with the heat gun, to ever so slightly expand it, which allows the colder bearing to slide easily into place. The bearing only fits in from one side as theres a ridge to stop it sliding through.... then the two little countersunk allen key head bolts are fitted through the casing and screwed into the 2 little retainer tabs which stops the bearing falling out the other side. Bit of loctite on these two bolts does no harm.... After that it's on to the replacing the 2 layshaft bearings...... the front old one is pulled off.... new bearing is heated up with the heat gun and popped on.... the bearing the other end is only a small bit more involved. The bearing is behind the last gear on the shaft, so the bolt and fat washer that holds this gear on is first removed, and then the gear is pulled off its splines on the shaft..... with the gear out of the way, the old bearing is pulled off and new one heated and slid on...... and then it's time for the first bit of shimming. When the gear is pushed back on the shaft on top of the new bearing, its up to the fat washer and bolt to hold them all secure and tight. If the gear was pushed back on the shaft and wasn't level with the top of the shaft, then when the fat washer and bolt were tightened down the gear and bearing would still be free to wobble around a little underneath it. So, with a depth gauge, the length of exposed shaft on top of the bearing (marked X below) is measured.... "X" was measured at 34.8mm. Then the length of the gear is measured (Y).... and as you can see it was 34.7mm So a 0.1mm shim is needed to bring the gear flush with the end of the shaft..... shim fitted, gear heated up and slipped on, fat washer refitted and bolt loctited and tightened back in place. Layshaft finished..... After that it's on to short the input shaft, replacing the front bearing first (making sure the recess in the outer race for the circlip is facing away from the gears as pictured)..... and then the little bearing in the end of the shaft. (new one fitted, old on on bench)..... After that it's on to the output shaft which holds the majority of removable pieces.There's a collar at one end of the shaft which means the shaft is built up in two steps as arrowed.... first up the long side is built up. The shaft is placed into special tool p/n 959axlestand to hold it secure...... first up one of those little double row needle bearings (like the one shown below) is slid on..... then 3rd gear and a syncro ring is slid on.... followed by a syncro hub. The syncro hub is a tight fit on the shafts splines so it's heated with the heat gun first to expand it and allow it to push on by hand (soon to be burnt hand)..... after that its another syncro ring (they're all identical to each other), followed by 2nd gear.... another of those needle bearing slides inside the gear (like the one pictured below)..... this bearing however isn't a snug fit on the shaft, instead it runs on a removable collar like below, so the collar is slid down in between the bearing and shaft..... After that, next on is the centre piece of the worlds most expensive gearbox bearing (yeah that price really got to me).... And thats as far as can be built up this end of the shaft at the moment, so, the shaft is rotated in the stand and we start building up the other end..... first on this end is another of those double row bearings.... followed by 4th gear and it's syncro ring..... and then a syncro hub (again heated in the centre to slide on easy).... and with the syncro hub in place, last to go on this end of the shaft is a fat spacer and a circlip to hold everything in place. Again everything has to be held on tightly this end of the shaft, there can be no play for the gears to move around. So, with that in mind, that spacer under the circlip comes in a range of different sizes, going up in small increments. Pop the circlip on without the washer under it, measure the gap below it and then use the largest size spacer that will fit to keep everything packed tight (use a new circlip going back, they only cost buttons and if the old one fails it'll cause the box to go "boom") ..... and with that done the input and output shafts are fitted together (one just slides in to the end of the other).... and then the whole lot is popped back up in to the stand again for a bit of measuring..... The measurement we're after this time is is marked "A" in the pic below. And it's the distance from the top of the expensive bearing inner race up to the next "ledge" on the shaft at the top of those splines..... same idea again as the layshaft shimming. The stuff thats going on the shaft here needs to be held tight by the stuff that comes on top of it. Only problem is the stuff coming on top of it will only fit down as far as this "ledge" in the shaft. So we've got to make sure this stuff fits on level with the top of the ledge. And this is done by measuring the piece of shaft with a depth gauge ( "A" = 52.5mm)...... Bearbeitet: 24. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1471994 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 13. Februar 2015 Autor #40 Meldung Teilen Geschrieben: 13. Februar 2015 (bearbeitet) And then measuring the stuff thats sliding on here. First of which is a syncro hub. Theres 3 of these in total in the box and while the other 2 are identical to each other, the one that fits here has 2 small important differences. The centre's of both the other syncro hubs are smooth on both sides, like the bit marked red below..... The one that fits here however has a small step in it on one side, arrowed below..... The second difference from the other two hubs is this little groove on one side of the outside ring, which doesn't concern us right now.... right, back to what we need to measure, one of the little needle roller bearing collars that fits inside each gear is held up against the smooth side of the syncro hub like so..... and using a micrometer we're measuring to the inside ledge of the step on this side of the syncro hub, like so...... which when measured came to 53.3mm ("B"). So the height of the stuff we're fitting to the shaft is 53.3mm and the length of shaft we need to fill is 53.5mm to bring them flush with the end of the splines. So taking "B" from "A" (53.5mm - 53.3mm) gives us the gap we need to fill with a shim = 0.2mm. That shim ain't been fitted yet though, we have a bit of assembly to do first. The input/output shafts and the layshaft are placed together like so..... the middle casing is popped up into the vise and the metal around the centre holes where the bearings fit into are heated up with the heat gun to expand them..... and then while it's nice and hot the shafts are offered up and slid through like so..... and now that the shafts are fitted to the casing we can pop on that little 0.2mm shim we measured.... followed by the bearing collar (which was heated cause it's a tight fit on the shaft)..... and then the bearing..... and then 1st gear is slid on meshing with 1st gear on the layshaft beside it..... next up was that shiny new syncro ring..... and finally that odd ball syncro hub, making sure that the recess cut out of the outer ring is facing in towards the casing.... the only snag is, when fitting this last syncro hub you've got to fit it's shift fork and rod at the same time..... like so...... because if you don't, you'll never get the fork on afterwards, and even if you did manage it, theres no access to knock in the roll pin that secures the fork to the rod...... There's two other things thats probably worth noting at this stage. The first is, theres a few little notches machined out of the end of the shift fork rod, circled below..... theres two ways you can roll pin that shift fork onto the rod, 1) like above with the notches facing downward which is correct, or, 2) the rod rotated 180degrees from above pic,which leaves the notches facing upwards, which you only find out much later is the wrong way around and means dissembling the lot to switch it around again. (the urge to take out a hammer and chisel and beat some new notches into it out of frustration will take a lot of effort to subdue at this point). The other point worth noting is although the 3 shift forks will only go together in the box the right way (they won't physically fit any other way) it still helps a lot, if upon disassembly, you scribe onto the side of each fork, an arrow showing which way it faces (towards front of box) and which syncro hub it came off (ie. 5th/4th, 3rd/2nd or 1st/rev). It just saves a lot of head scratching while you try to figure it out upon reassembly. Which when all assembled ends up looking like this..... once happy that all notches and forks look like they are where they should be, then it's time to hammer in the remaining roll pins.... With all that crap done it's back to building up the end of the output shaft again. Remember that last odd ball syncro hub that was fitted with the little ridge in the centre?.... well now we get to see why it was important the ridge faced out this way. These two little thrust type washers...... pop into that ridge..... which is then followed by the last syncro ring and reverse gear..... and the little bearing for inside the gear..... and finally heat up the bearing cone and slip it in between the bearing and the shaft..... next to go on is a 0.5mm shim, no measuring or calculating for this one, every box just gets a 0.5mm shim here..... One of the final things to go on the shaft is the last of the bigger main bearings. But before it can go on we needed to do a bit of measuring with it first. The bearing will be fitted on the shaft and when the rear casing is offered up and pushed on it will sit inside this recess in the casing..... and this support ring will bolt it tight into that recess inside the box.... if you just dropped the bearing into the casing recess and bolted on the cover above what you'll find is that it doesn't clamp the bearing real tight in there. The bearing will actually be able to move back and forth a little. So what you've got to do is measure how much "slack" is in there and pack it up with shims so that the support ring clamps the bearing tight when bolted up. To do this first we measured the depth of the recess in the casing (13.1mm)..... and then fitted the bearing into the support ring..... and measured how much stuck out (12.9mm)...... 13.1mm of a hole minus 12.9mm of a bearing to stick into it is going to leave you with 0.2mm of a gap in there, so, a 0.2mm shim is fitted under the bearing before it's sat into the support ring like so..... Now when all that is bolted together, that bearing is going to be clamped nice and secure between the ring and the casing. With the shims figured out and fitted between the bearing and the ring, the bearing could now be slid onto the shaft. The heads are cut off two long m6 bolts and these are screwed in to two of the five threaded holes of the support ring, for reasons you'll see in a while..... centre of the bearing is heated with the heat gun and slid onto the shaft..... and finally this little spacer is slid on..... After that it's time to get the rear casing ready for going on. Output flange seal is changed (available after market for buttons, size: 40x55x8mm)...... and then the selector shaft seal (size:15x21x5mm)..... and then refit the reverse idler shaft stuff..... the shaft sticks up out of the rear casing and onto it is dropped, bearing, spacer,bearing..... followed by the idler geared shaft..... and then a fat little spacer with a corner cut out..... As usual the cut out piece has to be in a specific location when the rear casing is offered up to the box and the chances of it staying as pictured when you lift the whole lot up is zero to none. So, fat blob of grease on the back of the spacer and stick it in place in the box instead.... The 2nd last thing needed in the rear casing before it can go on, is this.... There's five of these balls and three springs in total for the rear casing, only one spring is needed at the moment, and it slides in through a little drilling in the casing marked by the green arrow. (you can just about see the spring in place, red arrow)..... And finally just before the rear casing is offered up, bit of gasket poo and gasket is stuck to centre casing side.... And then just as your ready to offer the rear casing up, these 4 little roller/spacer thingies (*may not be correct technical name) are stuck into place on the selector shaft with the aid of four blobs of grease.... don't be shy with the grease on those, the little fu*kers love to drop off and head off for a wander while your shoving the rear casing on. And then at long last the rear casing can be offered up, but, it can only go on this far (because that'd be far to simple)..... quick check to make sure them 2 little m6 bolts that were screwed into the bearing ring have come through the casing in the right place..... and then the reason why the casing can't slide all the way home yet. That little spring is in the way of the selector fork rod sitting into it's final resting place..... So, one of the little balls like pictured below is placed on top of the spring in the casing and is pushed back into it's hole to let the rod by...... that sounds so simple when written, but in reality can provided hours of entertainment for all the family. And when you've mastered that one, it's on to the one next door, same idea, spring drops down from the top into place, ball on top and squeeze down to allow the next rod to push through, and, as if that wasn't challenging enough you've also got to place a ball directly between the two selector shafts aswell (that ball is hidden in this pic, the final pic in this sequence makes it a little easier to see where they all end up!)...... and then finally the last one's, again a ball between the two shafts and the final one sits on top of its spring and is depressed in it's recess to let the shaft by (at this stage you'll either be a pro at this or have set fire to the garage out of rage, if you look carefully you might just notice the fire extinguisher fumes in the background of this pic)..... when you've finally succumbed to the rage and decided to beat them all into place with the sledgehammer this is where all the balls should end up (red circles = the balls, blue circles = the end of the selector shafts)........ when they're all in place and all the rods are covering them, the casing can be tapped the final half inch home. Then the collection of 5 little plugs can be tapped back in, to cover all them drilling's in the casing..... Then it's on to the bearing support ring and them two long m6 bolts sticking out the back. The five bolts get a wee dab of thread lock.... The 2 long m6 studs sticking out the back should have kept all the holes aligned allowing you to fit 3 of them into the 3 empty holes ,finger tight, and then the two long bolts are taken out and replaced by the other 2 proper bolts...... When they're all in then tighten them up evenly. Front casing is nowhere near as dramatic. Stick the gasket on with some gasket goo either side, heat the centre of it up so it sides on easily over the bearings and then just batter it on..... When it's on this little collection of crap..... is battered into this hole, professionally...... After that the rear output flange goes on. A little gasket goo rubbed on the inside of the splines helps keep it oil tight..... special tool p/n 959rustybar makes a return to hold the flange while the nut in the centre is torqued up..... The nut no longer needs that brass type lock ring placed over it next, as the factory revised the procedure to just use loctite on the nut instead. After that and it's back to the front end to do the final bit of measuring and shimming. The spacer ring is first slipped onto the bit of the input shaft bearing thats sticking out..... followed by the circlip that snaps into the recess cut in the outside of the bearing..... when all thats fitted, a few soft taps inwards on the end of the input shaft to make sure it's fully home. (that circlip should be tight up against the spacer ring, which in turn should be tight up against the housing. With that done the little cover thats going to go over these bearings is preped. The cone/tube "thingy" that the clutch release bearing rides on (black yoke below) fits into the cover.... a tiny smear of gasket goo on the cover where the cone sits into to keep it oil tight. The cone also has a notch on it so it'll only sit in fully in one position.... with that in, the input shaft seal is fitted in to it (30x42x7mm, big money from main dealer for some reason, available for buttons aftermarket)...... and then the measuring. The idea of this cover is that the 2 bearings will sit into the two recesses in the cover. The recesses have to be shimed so that when the cover is bolted on tight theres no wiggle room left for the bearings. So to figure out what size shims are needed first up we measured the depth from the face of the cover to the bottom of the hole (the face of the cone/tube thingy)...... and that came out at 7.1mm, and then measured how much bearing was sticking out of the box...... and that came out at 6.8mm. So, from the hole depth..........................7.1mm take away the bearing height...................6.8mm and you get the size of shim needed ........0.3mm Only theres one other thing to take into account, that cover may have a gasket (some do, some don't) and when you fit a gasket it brings the cover back another tiny bit away from the bearing. So the manual says add another 0.2mm for the thickness of the gasket. So now the hole is..........7.3mm minus bearing height.......6.8mm equals shim thickness.....0.5mm Same sort of deal for the bottom hole/bearing. Measure the recess....... That came to 5.2mm, and then measure how much the bearing protrudes...... which came out at 4.7mm So once again, hole depth............................................. .....5.2mm plus the bit for the gasket..........................0.2mm equals............................................ .............5.4mm minus the amount the bearing sticks out....4.7mm leaves you with the shim size needed........0.7mm Only it doesn't, because the manual says this bottom shaft needs 0.1/0.2mm endfloat. Which means it needs a little space to move around and stretch it's feet. So from the shim size of 0.7mm (which would have packed it tight) you subtract 0.1mm to leave the true shim needed at 0.6mm (now the shaft has 0.1mm of space to move around in as speced). And if you understood all that, fair play to you, cause i'm writing it and it's making fu*k all sense to me as I read it back. Anywho, gasket goo'ed on, shims greased in place, it's time to throw the cover on.... 7 little bolts, 3 long for the top, 4 short for the bottom, get them the wrong way around and the long ones will screw in the bottom and right through the casing and burst your bearing inside, which is nice..... STAY TUNED Bearbeitet: 13. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1471997 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 13. Februar 2015 Autor #41 Meldung Teilen Geschrieben: 13. Februar 2015 (bearbeitet) Bilder stehen leider nicht zur verfügung and ta-daaaaa..... http://www.xworksmotorsport.com/m3%20build%20%2816%29/100_1851.jpg With the box overhauled it was time to turn the attention to the outside bit's and pieces. First up, gearlinkage. When I got this car the gear change resembled stirring a bowl of porridge with a large wooden spoon, it was vague to say the least. I changed one little bit of the linkage at the time, which helped, but I knew there was more to fix at some stage. So now the day has come. Theres 4 places where the linkage can get worn, and my car proving as helpful as ever was w*nked in all 4 places...... http://www.xworksmotorsport.com/m3%20build%20%2816%29/100_1799.jpg position 1 This bit is probably familiar to most e30 owners as it's the bit that wears most. It's cheap enough from the main dealer (p/n 25117503525) and it's handy enough to change....... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1813.jpg Position 2 Was a bit surprised to find so much wear here. The bolt had started to chew it's way through the bracket. Elongating the hole and wearing down the bolt.... http://www.xworksmotorsport.com/m3%20build%20%2816%29/100_1810.jpg http://www.xworksmotorsport.com/m3%20build%20%2816%29/100_1811.jpg Position 4 http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1802.jpg This is the little ball the the gearlever rotates on. As the ball is metal it doesn't wear, but the plastic bushing it sits in does. New bushing main dealer p/n 25111220600...... http://www.xworksmotorsport.com/m3%20build%20%2816%29/100_1803.jpg Position 3 The little bush just under the ball on the gearlever..... http://www.xworksmotorsport.com/m3%20build%20%2816%29/100_1805.jpg as you can see in the exploded part of the pic theres only a small bit of wear here, but it doesn't take much to make the lever feel sloppy. Theres no bush to change here, the only remedy is a new gear lever. Thankfully I had a spare Z3 one which was good to go.... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1806.jpg So, rob the post office on the way to the main dealer's...... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1814.jpg Z3 lever fitted..... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1807.jpg new rubber bush in the end of the stabilizer bar as it was worn too.... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1812.jpg fresh bracket and bolt fitted onto the new bush.... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1808.jpg and then time to fit back the lower link. Two new plastic washers fitted on the inside (p/n 25111220439 they're important and they're also the cheapest part you'll ever buy from a main dealer)...... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1815.jpg pop the link bar back in one end, with another plastic washer on the outside before refitting the circlip........ http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1816.jpg slide in the other end of the link........ http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1853.jpg pop another fresh washer on...... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1854.jpg and then the circlip...... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1855.jpg If them circlips are loose sliding on, then replace them, there should be a tight "click" as they pop on. If they fall off down the line, you'll loose the ability to change gear, and it won't happen close to home, it'll be in the middle of nowhere, it'll be dark and raining and you'll be the tight arse fool walking back up the road, in pitch black darkness looking for a lost clip that you were to tight to change. (yes, I wore that t-shirt). And then finally, rebolt the stabilizer bracket to the box with the two long bolts that are a pig to get to when the box is fitted in the car.... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1856.jpg after that, reverse light switch goes back in with a new washer.... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1848.jpg wires attached..... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1859.jpg and clipped on here..... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1860.jpg and here.... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1861.jpg before magically reappearing inside the rubber boot..... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1862.jpg (the wires in the above picture were the old ones and since fitting them and posting this up I've had a very helpful pm from a member over on E30zone to say that the old wires can short out due to age and in his case actually cause a fire. The wires are now being renewed tomorrow.) There was something not quite right about the geabox rubber mountings, but I just couldn't put my finger on it..... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1672.jpg http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1673.jpg so I replaced them to be on the safe side.... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1852.jpg bellhousing bolted back on along with the little bracket to support the exhaust downpipe...... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1857.jpg clutch fork, retaining spring and clutch release bearing back on..... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1858.jpg a lick of silver paint..... http://www.xworksmotorsport.com/m3%20build%20%2817%29/100_1863.jpg and thats a brief description of how we overhauled my gearbox. If you've made it this far, congratulations, most of what you've just read is probably wrong. But sure there was nothing better on tv anyway. Till next time STAY TUNED Bearbeitet: 14. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472000 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 14. Februar 2015 Autor #42 Meldung Teilen Geschrieben: 14. Februar 2015 (bearbeitet) Evenin all, Some big news to start off this update, you won't believe this! I still can't believe my luck myself. I've sold the car!! Its not even finished yet and I've had an offer I just can't refuse. A prince, no less, has seen the build thread and contacted me by e-mail to say he wants to buy the car immediately. I know, I know, unreal isn't it? And best of all is the price he's offered, two hundred and fifty thousand Ugandan Dollars. All I have to do is send him my bank account details, credit card details, full name and address so he can forward the cash and have his staff call to collect it. F*cking spam mail scamming vermin, if there was any justice in the world they'd all be rounded up and shot with a ball of their own shite! Anywho, back at the ranch, the worlds longest car restoration was continuing at it's usual hectic pace and next on the list of things to do was brakes, starting with the beautifully aged rear calipers..... pads out, sliding brackets slid off.... circlip off the dust boot.... and then pop the boot off the piston... and then I use a special method to remove the piston from the caliper. A burst of compressed air is pumped into the brake fluid inlet port on the caliper and the procedure goes like this. Little burst of air, piston comes out a tiny bit and springs back in, little bit more air, piston comes out a little further and springs straight back in again. You get pissed off with the lack of progress and give it a proper wack of air, piston hurtles out at warp speed and mashes your fingers between it and the caliper..... when the pain subsides, the piston and caliper bore are inspected. What you see below is the reason why bake fluid is recommended to be changed every couple of years. Brake fluid you see is hygroscopic, yep I've no idea either, however Wikipedia reckons that means "a substance which attracts and absorbs moisture". So brake fluid absorbs water and if it hasn't been changed in donkeys years the water content builds up enough to the level where it starts to rust the inside of the brake system, like so..... the last thing to come out of the caliper is the bleed nipple.... front calipers although being a bit bigger come appart exactly the same.... with everything asunder, the first port of call was to check and clean up the pistons..... the two smaller rear caliper pistons on the left and front pistons on the right. The area marked red is checked for any heavy scratches, pitting, scoring blah, blah, blah.... They were reasonably smooth so they were given a polishing up with 1500 grit wet and dry sandpaper. The condition of the area above the red mark doesn't really matter as much, all it has to do is press against the pad whereas the bit marked red has to slide in and out through the caliper seal. Any marks on it and it's probably going to make shite of the seal sooner or later and leak fluid..... after that, threads in the bleed nipple hole take a clean up (M7x1)..... and then the threads where the brake pipe screws in (M10 x 1)........ then the inside of the caliper bore is checked for markings and then also given a polish up with 1500 wet and dry..... next up for a clean is the sliding pins, with the aid of a 7mm allen key they screw out of the bracket..... The last thing to clean up was the calipers and brackets themselves and give them a coat of this stuff.... With everything clean, the rebuild could begin with the help of some oe seal kits, 2 for the front (p/n 34111153202) and two for the rear (p/n 34211157042).... A front kit consists of a square sectioned O ring and a dust boot, like so.... the O ring sits into it's recess in the caliper (red arrow) and then the inside lip of the dust boot sits into the narrower recess (green arrow)..... which ends up looking like this..... then the tricky bit, the seal and the caliper bore (NOT THE DUST BOOT) are given a smear of brake fluid to get them slippery before offering the piston back up for re-entry. The tricky part here is trying to get the piston through the front of the dust boot and started into the caliper bore. The new boot is very tight around the piston and easy to rip while trying to stretch on. So. A bit of compressed air again while the piston is held against the dust boot and "hey presto" the boot inflates and pops up onto the piston allowing it to be slid back in easily..... You can use your fingers to hold the piston instead of the piece of steel used above if you wish, everybody should build up a good tolerance of pain, it's good for you. The rear pistons are no where near as dramatic. Dust boot on piston..... new O ring in caliper bore, piston slid in, and when in, dust boot is popped over its lip (blue arrow).... and then the circlip is popped on to secure the boot..... bleed nipples are cleaned up and refitted with a tiny dab of anti-seize grease on the threads..... And finally the caliper bushes. The original ones had little hard nylon inserts inside them..... whereas the newer ones haven't. I guess the rubber is just a little harder now and they're not needed..... anywho, they push into the caliper like so..... Brakes done, onto the driveshafts. The inner and outer joints on both shafts felt slightly knotchy, so....... with most of the grease cleaned off you could see the circlip that holds the joint onto the shaft. If your taking these apart for inspection it's recommended that you mark the 3 pieces like shown below so they can go back together in exactly the same place..... when cleaned up you could see where 22 years of hard driving had led to the balls wearing a groove into the outer piece of the joint, which explained the slight knotchiness. But of more concern was the pitting that was found, the surface of the outer joint where the balls run on was starting to give way...... The outer joint (the one that slips into the hub) can't be dismantled like the inner one because the cap is crimped onto the cv joint. (red arrow) To get if off you have to burst it off, damaging it in the process.... after seeing the condition of the inside joints and deciding I wasn't going to reuse these shafts I had nothing to loose bursting off the caps and having a look at the condition of the outer joints..... and they were a hell of a lot worse than the inside ones the balls themselves were also fairly pitted, but your going to have to use your imagination cause I'm still to thick to figure out how the f*cking zoom works on this camera..... The shafts were replaced with a pair of GKN Lobro one's which are exactly what the original one's are and what you'll buy at the main dealer. Only they're half the price at the motor factors.... Up next was the rear beam and trailing arms. Over the years I'd been reading various methods used by some people to re-enforce the trailing arms and also seen pictures of the Z3 rear trailing arms and had decided I'd give it a go. This is probably way overkill on whats going to be a road car but sure the metal and welder are just sitting there, all it costs is a little time and effort. So, piece of tubing..... knotched out..... hammered on (making sure distance X 120mm is the maximum, otherwise the tube hits off the exhaust bracket on the beam whilst the arm is rotating on the car, tack them on and dummy build to check before fully welding)..... and then the next modification, which I think is to stop camber changes by re-enforcing the hub carrier part of the arm. Cardboard template first.... bit of 3mm angle iron.... chop, chop, file, file, measure, measure, offer up, f*ck, f*ck, chop, cho..... the one thing to be careful of with these is to make sure they won't foul the driveshafts when fitted. Even though the hubs aren't fitted you can hold the driveshaft up roughly in place and check the clearance before final welding..... Then the old bushes had to come out with the aid of a few sockets and some threaded bar.... and with the arms totally bare, off they went for sand blasting and powder coat, which left them looking like this upon return..... mmmmmmm, shiny parts........ first job on the re-coated arms was to re-insert some bushes. Originally they were fitted with oe offset bushes, which were a disaster to fit last time around. They pop in just as easily as normal ones but trying to get the offset right so you end up with the desired geometry changes can be a real pig. This time around we're going to try a different approach to altering the rear geometry. So, old offset bushes get binned (2 on top) to be replaced by standard bushes (4 in bottom)..... the bushes are again pushed in with the help of some sockets and threaded bar. Looking at the bush in the pic below, they are pushed in tapered end first (right hand side in pic)...... and they push in from the outer side inwards as this side of each eye on the wishbone is slightly tapered at the edge to help start them on their way..... as is always the case when trying to push something into a tight hole lubrication helps greatly..... with them all back in you should end up with the fat bits of the bushes sticking out towards the outside...... Next up, wheel bearings. A little of the powder coating had found it's way onto the inside of the hub so this took a little sanding up first.... then the new wheel bearings (aftermarket SKF) get battered into their hole until you feel them butt up solid against the back lip in the hub..... followed by fresh circlips..... and then the brake backing plate, secured by two little m6 bolts.... and finally the handbrakes shoes anchor bracket, which is secured by two little m8 bolts.... then with all that crap fitted the hub can be pressed back in..... remembering to support the inner race of the wheel bearing whilst doing so or else it shit's itself. Which is nice..... [/center] After that we moved on to the brake pipes while waiting for other parts to arrive (or more accurately waiting for the cash to pay for them to magically appear from somewhere). To no ones surprise the "rust jihad" had also launched an attack on the rear steel brake pipes and fittings at some stage and they weren't looking in their first flush of youth.... So, a roll of 1/4 inch copper brake pipe and some fittings..... mark out and cut the length needed to make each pipe (www.realoem.com really helps here, they list the length of each pipe, although it helps to always add 30mm to be safe).... after rolling the pipe off the roll and cutting it, it can look a little crap with kinks all over the place so a large hardback book or piece of timber rolled on top of it a few times usually gets it nice and flat..... next up is making a flare on one end of it. The end of the pipe needs a little filing or sanding to round it off, from this..... to this..... then we break out the brake flaring tool..... pop the clamp in the vise and pop the pipe through the correct size hole...... then using one of the....one of the.....f*ck, what are they called again, I think i'm getting alzheimer's, I'm going to have to start writing me name and address on the inside of me jocks soon. PIPE FLARES. using one of the pipe flares you pop the pipe through the clamp till it's level with the shoulder on the matching size flare, like so...... tighten up the screws on the clamp to grip the pipe tightly and drop some oil on the top of the pipe and on the inside face of the flare before dropping it on to the pipe..... apply the press and mushy, mushy..... and this is the result, the top face is good to go but underneath is tapered because the clamp hole was tapered this side...... and for the fitting being used the underneath needs to be flat, so, turn the clamp over to the non countersunk holes side..... Bearbeitet: 14. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472097 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 14. Februar 2015 Autor #43 Meldung Teilen Geschrieben: 14. Februar 2015 (bearbeitet) position the pipe again..... some more oil and mushy, mushy, again...... which usually gives you a nice fat flare on the end of the pipe (apart from the times it goes arseways which I've chosen not to mention)..... then spends hours of enjoyment trying to replicate the original pipes bends and kinks..... before offering it up to the wishbone to see just how much of a balls you've made of it.... when happy with the shape of it (or ran out of patience trying) it's time to mark and cut it for the flare the other end..... it's not possible to accurately describe in words the level of frustration thats felt when you make the final flare on a pipe only to discover you forgot to put the fitting on first. with the fitting on, the second flare can be done... and before final fitment some fresh clips cause the old ones were..... the other thing thats handy to have around at this stage of the build is a little tub of grease. Everything that gets fitted to the exterior of the shell gets a smear of grease first to stop water/dampness collecting between it and the shell down the line and causing rust to reoccur..... with the solid pipes done some stainless braided pipes replaced the standard rubber flexi ones.... before finishing with the flaring tool the rest of the brake pipes were copied..... and fitted..... Pipes done, onto the rear handbrake shoes setup which is made up of all this crap..... the shoes themselves were only fitted a little while before the car came off the road so they're barley used..... a good rub of 60 grit sandpaper brings the linings up like new again..... and then theres this little collection of stuff that likes to fall off the edge of the workbench and never be seen again..... starting with the row of 4 little bits on top in the last picture which make up the manual adjuster for adjusting up the handbrake shoes. This bit screws into that bit..... they then pop into this bit.... and finally this bit slides on over the lot, oh and copper grease everywhere this stuff just lives for the opportunity to seize up ...... Get it? Got it! Good. When fitted in place this little setup sits between the top of the two shoes. When everythings back together and you line up the brake disc so that you can poke a flat screwdriver in though one of the wheel stud holes and adjust the knurled nut (red arrow) to spread the shoes out towards the drum. and at the other end of the shoes is the actual handbrake mechanism, made up of this delightful pile of stuff..... fat pin drops in here..... and that slots in to here..... and the end of the handbrake cable..... connects in here with the aid of the smaller pin.... like so...... so that when your out playing in the winter snow you can pull the handbrake in the direction of the red arrow and spread the two little levers out in the green arrow directions, which pushes the shoes out against the drum, locking the rear wheels and spinning the car around like a pro, right up until you wack the kerb and f*ck up your brand new alloys..... none of which will happen until this stuff moves from the bench onto the wishbone..... again plenty of copper grease..... the other little collection of springs the sit on the brake shoes were fairly rusted, so Bmw sell the whole lot under one part number (p/n 34419064267)....... and they sit on like so...... anti rattle clips screw through the brake shoes and into the back plate..... the return springs can be a little awkward to stretch on in place So, a little bit of twine and a spanner makes it a little easier to pull them into their slots..... followed by brake disc back on and grub screw greased and refitted..... and align the disc to pop the flat screwdriver in to adjust up the shoes..... when thats done the brake caliper anchor bracket went back on..... a set of fresh oe spec Jurid 547 rear pads ..... were fitted.... along with the caliper..... caliper in place, sliding pins go back in. Copper grease on the pins and a dab of locktite on the threads..... with the pins tightened up, the caps go back on the rubber bushes to keep it weather tight..... and finally the anti rattle clips pop on....... The last parts needed to finish off the rear wishbones were the abs sensors. Unfortunately the old sensors had become quite emotionally and physically attached to the wishbones, so attached in fact that it took a large selection of hammers and some colourful language to separate them. Unfortunately the sensors didn't take kindly to this and in revenge bent into shite rendering them scrap...... Not the end of the world however as the wiring on the sensors was well past it's sell by date anyway...... what very nearly did bring about the end of my world, by heart attack, was the price i got quoted for 4 new sensors. Obviously these are also made from moon minerals. Thankfully Colm_Mc came to the rescue with 4 sensors that looked as good as new (thank Colm I owe you one)..... just for the record the rear sensors are interchangeable..... while the fronts are sided left and right as denoted by the little "L" and "R" on them..... a good smear of grease on the sensors before fitting should mean future hammer massages are not necessary for removal down the line..... Which brings us up neatly to the end of the first half of this update, join us tomorrow evening for the concluding episode.......... And now we return to the conclusion of this years update. With the wishbones complete it was on to the rear beam....... As mentioned a little earlier the car used to be fitted with eccentric wishbone bushes to try and dial out some of the excessive camber that comes with lowering the car. However these were a pain in the arse to get right and needed to come in and out 3 times to get them exactly right, which is a lot of ballache. So this time around we're going to try one of the other options, which involves welding these little brackets on..... and using these 5 series eccentric bolts and washers..... I've only got two crappy phone pics of the welding on of the brackets as it was done in work in the day job, and as this beam doesn't look remotely like anything fitted to a double decker bus, I thought it might be better not to draw attention to it by doing a photo shoot . The pair of brackets welded to the outside wishbone pickup point are placed with the original bolt hole smack bang in the middle and the slot in the bracket is placed horizontal. The idea behind these two is to be able to adjust rear toe in/out. As the rear toe isn't to greatly affected you don't generally have to move the wishbone forward or backward a great deal to get the ideal setting..... The inside pick up points are a different story though. The main reason for doing all this is to be able to correct the negative camber gained by lowering the suspension and as such the brackets fitted to the inner pick up point have the slot vertical and place the original bolt hole right at the bottom like shown which gives you maximum scope for raising the inner pickup point and getting rid of some of that excessive negative camber ...... and with everything welded up and the original bolt holes filed out to match the new elongated slots this is roughly how it all should work (red arrows adjusting camber, blue for toe)...... which looked like this after returning from powder coating...... next up, the eccentric bolts that move the wishbone pick up points up or down. The bolts have little indents on the top face of them so as you rotate the bolts you can see how many indents it takes to add/subtract a certain amount of camber/toe....... however when all this lot is fitted back in the car you'd need a neck like a giraffe to see these markings, so, marks are traced out to the edge of the bolt head..... and over the edge where they're enlarged with a hacksaw blade which should make them a little easier to see back on the car..... The other thing that can be helpful is a reference point on the actual beam, so with the aid of the dremel..... a few little groves are etched and filled in with white paint...... all of which should make adjustment down the line a little easier, or, I've just waisted a load of time for nothing, we'll see. Before fitting up the wishbones to the rear beam the inner faces of the bolts and washers are given a coating of grease to help them rotate when adjusting...... a fresh set of beam bushes are fitted and the washers fitted on top with grease everywhere as these bit love to seize.... some fresh anti roll bar links and handbrake cable brackets are fitted to the wishbones...... The other little bits needed at this stage is the spring pads, the two arrowed are for the bottom of the springs and the other two with the bump stops in the middle of them are for the top. The whole lot is built up on a sheet of ply wood so it can be slid under the car when complete and jacked up into place..... before that can happen however the beam mount bolts have got to be refitted to the shell, before they are dropped in they're plastered with anti-seize grease..... and then they're dropped down into place in these holes at the edges of the floorpan under where the rear seat goes..... The other bits needing refitting before the axle can be lifted back up in to place is the rear shocks...... Bearbeitet: 14. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472100 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 14. Februar 2015 Autor #44 Meldung Teilen Geschrieben: 14. Februar 2015 (bearbeitet) First up gotta assemble them. These "gigantic" bump stops slide on..... followed by the dust boots...... and then a fresh set of top mounts..... followed by a bevelled washer and nut...... The other little bits that were to be fitted was the little plates fitted to Z3 rear shocks, pictured number 9 below...... When the shock is refitted to the shell the top plate on the shock mount does a nice job of spreading out the load when the body is pushing down on them. However when the situation is reversed and the shock is pulling down on the shell all thats spreading the load on top of the turret is two little m8 nuts, which sometimes can lead to stress cracks around the nuts. These 2 little steel plates which were used on the Z3 can be fitted under the nuts to help spread out the load better. Which is all marvellous but I'd forgot to order them from the dealer and was now ready to refit everything and was in no mood to have to wait another few days for them to arrive. So, the tight arse's guide to top mount plates...... Unfortunately the only flat steel I had lying around was 5mm thick and took forever to cut and file to shape, on the bright side should I ever decide to drive off a cliff the rear shock mounts should be well up to it...... and then at long last fire it all back into the shell..... Bearbeitet: 14. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472102 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 14. Februar 2015 Autor #45 Meldung Teilen Geschrieben: 14. Februar 2015 (bearbeitet) And then there was the front end. One nasty front subframe..... one freshly powder coated front subframe...... done one mod to the subframe back when I first got the car and this was down to the fact it had started to crack across the red line in the pic below (red circle is where the engine mount bolts down to and the reason why this bit started to crack off)....... the subframe was given a fresh weld across the red line both sides and plates fabricated up and welded on underneath to strengthen the whole piece. Only thing to watch out for is to cut a hole in the plate so you can still get a socket through it to tighten the engine mounting bolt..... First thing to go back on the subframe is the front antiroll bar, which is bolted on by these two little lads.... I've yet to remove one of these that wasn't caked in rust on the inside so a little smear of grease should slow down the antiroll bar bushing rubbing the powder coating off the inside so quickly...... And then the only polybushes to get fitted to this whole car. As you've probably seen by now I've replaced more or less every bush with standard rubber ones and the reason is I don't want to feel every pebble on the road. I don't want to involuntarily brace myself every time I see a pothole coming. I had cars when I was younger that the springs and shocks were probably just ornaments on, there was that little movement in the suspension, and although polybushes and stiffer this and that make for a faster car around a track, this car was a bloody good drive on the road when it left the factory on standard bushes according to any press releases from back in the day. I'm probably just gettin old (I'll probably be fuckin geriatric by the time this thread gets finished). Anywho, bushes came with the car when I bought it and there perfectly good to go again..... A heavy smear of grease where the subframe mounts up to the chassis legs should keep the moisture(rust) out..... Rear antiroll bar was back from powder coating to so it got bolted back to the floor pan..... And then the front struts which made the most dramatic transformation of all the powder coated bits..... The front spindle gets a rub of 1200 grit to polish it up..... then the rear dust cap gets popped on..... followed by the backing plate...... and next up is the wheel bearing. As is well documented around the interweb by now the E28 wheel bearings and e30 M3 bearing are the one and the same unit, only difference being different ABS rings and a big difference in price. So, pair of E28 bearings....... pull the Abs rings off..... and then pull the rings off the old M3 bearings....... These were seriously tight and I had to rely on the age old 3 stage method to remove them. Step 1...... Step 2...... Step 3..... bingo..... Rings get a clean up and a little loctite on the inside lip for refitment.... and when securely back in place a lick of silver paint to protect the bare metal..... And then drop the whole lot back on to the spindle. Unlike the rear bearings the front ones aren't usually tight going back on and don't require a press. A few gentle tips with something soft and they should slide down into place..... When there back on, the nut is screwed up and torqued with a size 46mm socket..... after which the little rim on top of the nut is clenched into the cut out on the spindle (which is probably the most long winded way of saying, bend this)............ and then the the front dust caps are fitted with a little smear of grease on the inner rim to help keep them water tight...... Next up the shock absorber. Threads at the top of the strut tube get a little clean.... and then the front insert is dropped in. The shocks by the way are Bilstein gas shocks and I remember reading somewhere that unlike the normal procedure of filling the gap between the shock and the inside of the strut tube with oil, with gas shocks its recommended to leave this space empty. So I just gave it a few squirts of the oil can to keep it from rusting in there....... This little dude screws down on top of the shock into the tube and keeps it secure. I used to have the special tool for screwing these in, but I lent it to a person(bastard) a long time ago, and that person(bastard) forgot to bring it back and I've forgotten who that person(bastard) is. But one day I'll remember who the person(bastard) was and that Bastard is in for a surprise. The little item arrowed below is for securing the shock dust boot and it's very important to remember to fit it before screwing down the shock collar.... F*****************************k........... Next on is the springs which also paid a visit to the powder coater..... Springs by the way are Eibach and are listed by them for the 318is I think. They're practically the same poundage as the original M3 springs but just sit lower and I was happy with the ride and handling before the car came off the road so there didn't seem to be much point in changing them. Before the springs can be fitted they need to be compressed with the aid of spring compressors and a few bits of rubber tube so as not to scratch the powder coating back off again....... on either side of the springs go these rubber seats so they don't squeak as your driving along...... one goes below the spring like so........ and one sits onto the top spring platform like so...... after that the strut top mounts go on. These are offset ones (p/n 31331139484) which as you can see in the pic the hole in the centre is offset to one side a little. And if fitted the right way around they will move the top of the strut in towards the engine a little (half a degree) and give you a little more camber at the front wheels, which should improve road holding. In reality the change (half a degree) is so little any effect they have is going to be small but if your changing the top mounts anyway they aren't a great deal more expensive then the standard ones...... the new mounts don't come with the three little studs needed for fitment..... So, nuts on to protect the threads..... pop them up loosely in the vise..... and batter the living shite out of them...... and now the reason I said they can help "if" fitted the right way. Theres 6 holes on the mounts and you've 3 studs to fit, so which holes to use? On the underside of the mounts 3 of the holes are marked with a + and 3 with a - . As we're trying to subtract camber (add negative camber) the studs are fitted to the 3 minus holes...... with that sorted it's on to actually fitting the mounts to the strut. 5 items in total Strut mount 1) small washer 2) large washer 3) bevelled washer 4) nut on the underside of the mount you can see the strut top bearing which comes pre greased...... the bevelled washer(3) is topped up with a little grease on the inside..... and popped down on top of the bearing..... (Leider fehlen die nachfolgenden Bilder) and then the large flat washer(2) is slid onto the strut followed by the mount...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2129.jpg which is then followed by the small washer(1) and nut(4)...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2130.jpg after the nut is tightened down the spring compressors can be removed and the little dust cap popped back into the centre of the mount..... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2131.jpg after which the ABS sensors were refitted.... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2177.jpg and the final bits to go back on the struts are the brakes, a fresh set of disc's...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2179.jpg http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2180.jpg and then the calipers bolt back on just like the rears, which leaves them looking like so...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2186.jpg The other bits needed before the struts could be bolted back into the car was wishbones and "lollipop" bushes. These are M3 bushes the differences being over standard e30 bushes the hole in the centre is off to one side and there more solidly packed out with rubber...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2134.jpg theres a little arrow on them to help you press them into the lollipops in the right place...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_lollipop%20bush.jpg http://www.xworksmotorsport.com/m3%20build%20%2823%29/lollipop.jpg To go with them is a fresh set of Lemforder wishbones.... http://www.xworksmotorsport.com/m3%20build%20%2823%29/wishbones.jpg and anti roll bar drop links...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2216.jpg After which, everything is rebolted back onto the car and when I could see which bolts were needed to reconnect everything I could order them all in stainless steel to replace all the manky rusted old ones..... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2202.jpg Which leaves her looking like this...... http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2332.jpg http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2331.jpg http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2339.jpg One giant leap for man, one small leap forward for this project........ http://www.xworksmotorsport.com/m3%20build%20%2823%29/m3_2256.jpg And that brings this update to a close which is perfect timing as tomorrows Saint Patricks day and I'm away to get very drunk. Till next time........ STAY TUNED Bearbeitet: 14. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472103 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 14. Februar 2015 Autor #46 Meldung Teilen Geschrieben: 14. Februar 2015 (bearbeitet) Die hälfte der Story haben wir durch Gab es bisher Probleme mit den Bildern? Das neue Forums System sammelt nacheinander gepostete Posts in einem Post, was mir eigentlich nicht gefällt. Mann müsste immer paar Minuten warten damit es separat postet. So werden die seiten zu lang. Falls mann das wie früher machen kann, lasst es mich wissen, da ich wie im original Thread jeden post separat bearbeite anstatt alles zusammen zu machen. Es ist ja auch eine Thread-Restauration; Respekt zum original Grüße Kurt Bearbeitet: 14. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472105 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 17. Februar 2015 Autor #47 Meldung Teilen Geschrieben: 17. Februar 2015 (bearbeitet) Evenin all, Been a while since the last update, the reason being I appear to have well and truly busted something in my back. I'd love to give you a more accurate diagnosis but unfortunately my doc is a foreign lad and for the life of me I can't tell what he's saying half the time. But judging by the serious look on his face and the size of the horse tranquillizers he's prescribed for me, I'm guessing i'll not be doing cartwheels any time soon. But as they say, every cloud has a silver lining and despite the fact you need a knife and fork to take the pain killers the effects of them are marvellous. I now wear a permanent "stoner" grin all day long and can walk through brick walls without so much as an itch. Anywho, before this post starts to sound more like an bleeding heart letter we'll move on to what I've managed to mess around with on the car this time. First up I need to put my hand up and admit to a co*k up from the last update. For those who can't remember back that far, I had welded in some reinforcement bars on the rear wishbone's like so...... Well not long after posting up the pic's and details on the web I got a heads up from a member on S14.net to say he'd tried the same mod and ran in to some difficulties upon refitting them. The difficulty? When the wishbones are refitted, just above them runs the rubber fuel filler pipe that carries fuel down from the filler flap to the fuel tank under the car, like so...... (modified tube in purple, red arrow is where the fuel will run into the tank, when fitted) Which all looks fine and dandy, until you realise thats with the wishbones in full droop. As soon as you lower the car back onto the ground the wishbones go back up towards the floor plan and squash the rubber filler pipe flat. fu*k. Making it impossible to fill the car with fuel. double fu*k. So i retired to give the matter some serious thought....... And then, when all seemed lost, it hit me, I had a brain wave, a perfect solution to the problem, it was so simple i couldn't believe I hadn't thought of it earlier ..... cut them out, fu*k them away and move on. Next up, the alternator. Or to be more precise, pull it asunder, fiddle about with it and then try and figure out how it goes back together again. Starting at the rear end these bits and bobs came off first..... Number 4, the earth lead. Responsible for earthing the alternator to the chassis via the engine block...... this needs to be in good condition as you can get all manner of strange electrical faults if this lead starts to fail due to corrosion of the terminals or the copper wire inside corroding. As this one was starting to show its age and the outer insulation was badly cracked, a new one was made up to replace it...... Number 3, the suppressor. This little dude just bolts on to the back casing of the alternator and the little wire from it connects to a male spade terminal which sticks out of the casing. It's purpose is to stop electrical interference from the voltage being created inside the alternator from messing with other electrical systems on the car. Like the stereo buzzing up and down as the engine revs rise and fall. Nothing much to be done with it, if it works it works. If it doesn't, get a new one..... Number 2, the wire terminals plastic insulation. There's just two wires that go to the alternator, a big fat one which is main battery power and is connected back to the battery positive terminal via the starter and a little wire which comes from the battery light up on the dash. Both these wires are live and if they manage to touch off the alternator casing, which is earthed, you'll get a nice little fireworks display right before the fire starts. So this little plastic insulator lets the wires bolt on to the two studs sticking out without touching the casing. To remove it, the two nuts that hold the wires in place come off and then another two nuts below this come off to let the insulator slide up and off....... And finally, number 1. The brush pack and regulator. Undo the two little screws and it lifts out of the casing. This thing is the most common reason for alternators failing to charge. An alternator has a shaft rotating inside it (rotor), and for the alternator to do it's thing and produce some voltage you've got to pass a current onto this rotor and then give it a route to get back out again. To do this the shaft has two brass rings on it, which we'll get to later, and two little carbon "brushes" (red arrowed below) are pressed against the brass rings allowing current to pass in through one, do it's job and then pass out back up through the other. The little brushes seen below, have little springs underneath them to keep them rubbing against the rotor all the time as it turns. Eventually the little brushes wear out and can't reach the slip rings any more and the alternator stops charging. The other part of this little unit is the little black thing on the front (blue arrow) which is the voltage regulator, and as the name suggests it's job is to control the voltage coming out of the alternator. To much voltage could damage other electrical systems in the car so it drops the voltage down, to little voltage been produced (headlights, demister, rear window defogger all on) and it raises back up the voltage. All the time it's trying to keep the output at roughly 14 volts. In the pic below you can see that the brushes in my brush pack were on their last legs and hadn't to long left to go when compared to the new brush pack next to it...... If your alternator packs in, this is one of the first things worth checking. A new brush pack is only about 10/15euro from a motor factors. And once you've the alternator off it's just a matter of undoing the two little screws and lifting out the brush pack to check the height of the brushes. There's a few different brush packs fitted to e30 alternators due to the alternators having different power outputs, so if your going to order one use the part numbers on the old brush pack to make sure your new one is a perfect match. One final little piece of advice, if your changing a brush pack, go softly, the little carbon brushes are brittle and don't bend, so be gentle sliding it in to place. Use the force Luke, not the hammer. With all that stuff stripped from the rear end it was time to flip it over and start on the front. The centre of the shaft has a hole to accept an allen key so you can hold the shaft while loosening the front pulley nut. The pic below shows the order in which the collection of washers come off. Whats interesting if you've never stripped one before is the alternator pulley isn't actually a solid pulley, but instead two concave washers squeezed together...... Once that stuffs off next up is the 4 main bolts that hold the casings together. Before splitting the casings it can help to make a little mark or scribe a line on the 3 main bits of the alternator so they can be bolted back in the same orientation...... Its also worth making a mental note that of the four bolts that hold the casings together, two are longer than the others. Reason being when in place these two stick out the back of the alternator casing a little bit and are used to screw clips onto to secure the wires going to the alternator. They need to go back in to the same hole on reassembly...... with them 4 bolts out of the way, next up is the 4 inner ones shown below....... and then with some gentle persuasion (beating and cursing) the front casing "should" just slide off...... next up, the rear casing and stator (middle bit). Sometimes these will slide off easily, but as is always the case with this fu*king car, these were not going to come off without a fight. Shaft gets tightened in the vise (with soft jaws so as not to mark the shaft)....... and this little dome on top of the rear casing which houses the rear bearing gets a little heat from the heat gun to expand it and help it let go of the bearing inside...... and hey presto, off she comes. Once these two pieces were off they separate fairly handy. Rear casing on the left, stator and diode pack on the right..... First item to be changed in here is the diode pack. Old one still attached, new one below it..... Without going to deep into the black magic that happens inside an alternator, the main job of this diode pack is to convert the AC voltage which the alternator makes, into DC voltage which the car needs. There, thats as clear as mud isn't it. AC voltage is the stuff that powers your house, and AC is short for alternating current, which basically means the little volts travel backwards and forwards like mini Duracell bunnies on coke..... and AC voltage is no good for a cars power system which is DC voltage (direct current), where all the little volts march along in the one direction nice and calmly. So the diode pack has a little bunch of diodes in it which are basically one way valves for electricity. They'll let the voltage through but not go back again. And so convert the AC back to DC voltage which the car can use. (If you listen carefully you can actually hear Albert Einstein spinning in his grave after that explanation). In the pic below the main roundy bit (the stator) is where the black magic takes place and the AC voltage is made. And connected to this by four wires is the diode pack in the middle.... I don't think the diode pack has a certain service life really, theres no wearable parts in it like the brush pack has. However over time the diodes can fail and stop the alternator charging and as I'm changing everything else in here Murphys law states that if I reuse the old one, it'll fail down the road just to p i s s me off for not changing it while it was all asunder. So, heat up the solder and pop the wires free.... and then solder the wires back in to the new diode pack. Best to have the soldering gun nice and hot for this, so you can solder each joint quickly. If too much heat soaks into the diode pack it can fu*k it up..... with that done it's on to the rotor, and changing the bearing at either end of it. The one on the left is a straight forward, old one off, new one on affair. While the one on the right, the larger of the two is a little more involved. In front of the bearing theres a fat little shim and behind it there's a little square plate. The little plate is what the 4 little screws removed from the outer casing back in the beginning screw into. And it's purpose is to keep this bearing snug and tight up against the casing and not wandering up and down the shaft...... The other job that needed doing while the bearings were off was to change the brass slip rings. As mentioned earlier the two little brushes in the brush pack rub against these slip rings, and just like the brushes these rings also wear down over time. You can see in the pic below the two grooves that have worn down into them. Usually you'll get through about 2 or 3 sets of brushes before the slips rings need to be changed and by that stage most cars are at the end of their life. However, as this car has 24 years under her belt it's not that unusual that they're this worn...... they're a tricky little fu*ker to change though. In the pic below you can see two wires coming out of the centre of the rotor and going into the slip rings where they are soldered on. So the slip rings are carefully sliced with a small cutting disc on the dremel, on top and bottom like so........ and then popped apart. The wire on the right (purple) is soldered to the inner edge of the inner ring and the wire on the left (green) runs up the inside of the rings before soldering on to the outer edge of the outer ring....... With the old rings removed and the wires cleaned up and the shaft where they sit cleaned up with some emery paper, the new rings are slid on making sure that the green wire in the pic slides up through the middle. With everything back in it's rightful place the wire ends can be soldered back on. The one thing to be careful of is that the wire insulation is in good condition when doing all this, as if either of them 2 wires touch any part of the shaft or rotor because of a break in the insulation then they'll just short out and blow the alternator when it's refitted...... with the slip rings done the new bearing can be pushed on this end...... and then turned around and plate, new bearing and fat shim fitted to the other end..... With all that crap done, it was on to the alternator casing bushes. Pull them out and check their condition.... circlip and washer off...... and then the insert can push out the opposite side...... (Nachfolgende Bilder stehen nicht mehr zu Verfügung) and then you can pop the bushes out. To my surprise it seems a previous owner has fitted polly bushes instead of the original bushes, and they're still in perfect nick...... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2391.jpg From reading on various forums it seems this change from original rubber bushes to harder polly bushes is to cure an inherent problem with alternators on the M3's S14 engine. The engine likes to vibrate a lot especially when your driving arse out of it (as all M3's should be). And this makes the alternator with the standard bushes vibrate a lot too, which can snap the adjuster bracket and leave you without a working alternator. So the polly bushes stiffen things up a bit and makes life a little easier for the adjuster bracket. At least thats my understanding of it, no doubt I've probably got it arseways as usual. With all the bushes checked and the casings cleaned up it was time to nail it all back together and hope for once that you don't end up with bits left over. First up the 2 little studs that poke through the back of the casing to attach the power leads to, making sure the little inner plastic insulators are in place so that the studs can't arc off the casing, spark, fire, boom, tears....... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2402.jpg pop it into the rear casing...... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2403.jpg and pop the outer insulator back on securing it with the two little nuts. Also the little suppressor dude goes back on...... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2404.jpg then the stator (outer bit) and rotor (inner bit) sits down into the casing. Rotor may need a little tap to get the small bearing the other end of the shaft back into it's little dome in the casing...... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2406.jpg http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2408.jpg and then finally the front casing pops on (making sure you've aligned the 3 markings you've made on the casings before stripping). Then the 4 main outer bolts are refitted and tightened to hold the casings together and finally the 4 inner screws that hold that little plate behind the front bearing tight to the casing are refitted. When all thats done the brush pack can be slotted back in (softly, softly)..... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2410.jpg and the earth lead reconnected........ http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2413.jpg followed by all the bits that make up the front pulley section...... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2425.jpg and voila!....... http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2433.jpg After this it was hooked up to our state of the art, mobile, water cooled, alternator test bed to check it was charging........ http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2434.jpg engine running and everything electrical turned on and bingo 14 volts at the battery. Didn't even need to use the fire extinguisher, how professional is that? http://www.xworksmotorsport.com/m3%20build%20%2824%29/m3_2435.jpg And thats about it for now. Depending on how whacked I get on pain killers this evening I hope to have the next bit up tomorrow. Till then....... Next up the starter....... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2414.jpg Two main bits to the starter, the big bit on the bottom is the actual motor that turns the engine over and then the smaller bit on top which is the solenoid. And it's the solenoid thats first to be removed. Three screws at the front are undone..... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2414b.jpg and on the back end, the nut shown below is undone and the main power lead to the motor underneath is removed..... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2418.jpg Which leaves the solenoid free to be removed (don't lose the little spring left behind its important!)..... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2419.jpg next up, the two main bolts that hold the motor to it's nose casing...... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2420.jpg which allows the nose casing to be removed and reveal the starter pinion gear (bit with the teeth) and the solenoid linkage...... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2421.jpg here's how I "think" it all works. The pic below shows the terminals of the solenoid which sits on top of the motor..... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2414c.jpg The starter takes a fair whack of juice to get it to turn over, and as such, it needs a fat wire to carry all that power down to it. It doesn't make sense to run the wire through the ignition switch on it's way to the starter because you'd need a bloody huge ignition switch on the steering column to be able to handle that amount of power. So, The main feed for the starter (big fat black wire direct from the battery positive terminal) runs directly to terminal 1 on the starter solenoid shown above. When you turn the ignition switch to start position, power comes down a smaller black/yellow wire to terminal 3 and travels across inside the solenoid to terminal 4 and earths. While travelling across to terminal 4 it energises a little magnetic coil inside the solenoid, which pulls in a set of contacts, and allows the big power from terminal 1 to flow over to terminal 2 and start the motor turning. So with all that done the starter motor is now turning over, the only problem is the little starter gear (pinion gear) on the front of the starter that engages with the flywheel ring gear to turn over the engine needs to be pushed forward to reach the flywheel. (if it was in contact with the flywheel all the time the starter would sh*t itself as the engine revs started to rise) So, the solenoid on top of the starter has another little job to do. In the pic below the little green metal cylinder on top of the starter is pulled (magnetically) into the solenoid when you turn the key to the start position. And attached to the back of the green cylinder is a little green linkage with a fork on the bottom end. The blue part in the middle is fixed and acts as a hinge point for the green linkage. As the top part is drawn into the solenoid the bottom part (pinion gear) is pushed outwards and into contact with the flywheel ring gear. And now the starter is turning the engine. Thats pretty much what happens when you turn the key, motor starts tuning and the teeth push out and engage with the flywheel and crank up the beast. As soon as you let go the key, the magnetism thats holding the green cylinder in, is lost, and that little spring shown earlier pushes the cylinder back out, which in turn pulls the starter teeth back away from the flywheel. http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2422.jpg Sometimes if your trying to start a car with a flat battery the engine just makes a clicking sound but doesn't turn over. Theres enough power to pull the cylinder into the solenoid and shoot the pinion gear out to the flywheel (which is the little click you hear) but not enough power to travel down the fat wires and turn the engine over. The pic below shows a starter which has been disassembled using the "f*ck, what did I just drop, I wonder was it important" method..... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2424.jpg and the one below shows a starter which has been reassembled using the "it'll be a f*cking miracle if this ever works again" method...... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2440.jpg last thing to do upon reassembly is bench test it. A set of jump leads, big power to terminal 1 and the earth lead clamped onto the casing. Any finally a little piece of wire to give a dart of power to the smaller terminal 3, which should bring the starter to life. If it doesn't, beat it to death with and hammer, hide it under the bench, and tell anybody who asks, "it was to far gone to repair"..... http://www.xworksmotorsport.com/m3%20build%20%2825%29/m3_2437.jpg Staying on the theme of motors, next up was the wiper motor and linkage..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2322.jpg plastic cover pops off to reveal the motor..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2323.jpg on the other side is the bolts to disconnect the motor from the linkage. 3 red arrowed bolt release the motor body and the purple arrowed nut releases the linkage from the motor spindle..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2324.jpg strip of water sealing tape removed...... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2325.jpg to reveal the two screws that hold the two halfs of the motor together...... (one this side in pic and one directly opposite the other side) http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2326.jpg screws undone and black bit slid off..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2327.jpg all i'm interested in checking in here is the motors brushes. There's 3 of them...... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2328.jpg You can check the condition of the brushes with just stripping as far as above, but since I've a mental dysfunction which makes me want to strip everything down to the last nut and bolt, belows a clearer picture of the brushes. Theres 3 of them, only two sticking out of their housings below (red arrows)...... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2350.jpg as the third one is the earth brush and is connected to the housing..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2351.jpg all the brushes still had plenty of life in them so everything gets cleaned and jumbled back together...... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2360.jpg remembering to put some tape around the top part again so water can creep in and fu*k things up in there..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2361.jpg after that it was on to the linkage....... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2362.jpg on top of the linkage spindles are a large nut and two washers which secure the linkage to the scuttle panel on the car, and if yours is out and on the bench these will already have been removed. Just in the centre of this though is a little small circlip...... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2363.jpg which when undone allows the spindle shafts to slide out of their housings. Both shaft and housing (purple and red arrows) each side get cleaned up and greased to help prevent against noisy wipers..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2364.jpg after which the joints in the linkage are done. These just pry apart, softly, with a large screwdriver (be careful not to damage the rubber booth)..... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2365.jpg when apart they're cleaned and inspected. In one of them the grease had gone hard and the linkage was just starting to wear a groove in the ball. The one on the left below is the good one, and on the right you can see the wear grooves just starting on the ball.... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2366.jpg thankfully the ball wasn't badly grooved yet and it cleaned up nice with some fine sandpaper. When these get badly grooved the wiper linkage starts to get annoyingly noisy and the wiper blades get sloppy on the windscreen. With everything cleaned up, they were all reassembled with plenty of fresh grease and the wiper motor reconnected....... http://www.xworksmotorsport.com/m3%20build%20%2830%29/m3_2367.jpg refitting of wiper linkage to car is an interference fit, for this reason it is recommended that special tool part number 959sledgehamer is locked away before undertaking said task. And thats it for tonight. Join us again tomorrow night for more cliff hangers, plot twists and the continuation of the worlds most monotonous thread :wink: Till then...... Bearbeitet: 17. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472619 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 17. Februar 2015 Autor #48 Meldung Teilen Geschrieben: 17. Februar 2015 (bearbeitet) Apologies for the delay getting this next part up, I had half of this waffle typed up and then the interweb broke, or something, and it all disappeared. It took a little time after that to fetch the computer from the neighbours front garden and reassemble it all again. Anywho, back to the story....... Next to get refitted was the ABS motor, nothing much to do with this. It was removed from the car in the beginning just as you see it below. And all of the pipes that had to be disconnected from the unit on removal had the open ports plugged to stop the fluid draining out of the motor. These can be a bit of a pig sometimes to bleed out upon refittal it she's been allowed to completely empty inside..... Just before fitting it, the little protective cover is popped of the rear end to check the condition of the electrical connections for all the stuff in there. The relays are pulled (red arrows) to check for any corrosion on the pins beneath which may have been caused by dampness getting in. And the pins sticking up (purple arrow) where the main ABS plug will fit on are also checked for corrosion. All clear, she was good to go...... after that the brake servo and master cylinder...... two nuts undone from the servo allows the master cylinder to drop off...... servo was looking a little second hand, so she got a sand and lick of paint..... On to the master cylinder, the little reservoir on top just pulls off (gently)..... then the two rubber grommets pop out, and you can see the little slotted washer in the port of the rear chamber..... washer just lifts out and needs to be remembered upon reassembly. The purpose of this washer is top secret. I could tell you, but then I'd have to kill you. (yep, I haven't a clue either)...... The ABS type master cylinder isn't constructed with overhauling in mind, hence the circlip on the front with no holes to get a circlip pliers into (marked red). And with the main dealer listing no internal parts and the motor factors drawing a blank as well, I decided to leave well enough alone. I've no intention of renewing the cylinder just for the sake of it, they're fairly pricey, and this one is showing no external signs of failing. If she does down the line, then I'll replace it. A mod that seems fairly common out there, is to change the master cylinder with one from a seven series bm, which has a larger internal bore and as such stiffens up the brake pedal a lot. I've driven an e30 with this mod done, and it ain't for me. The brake pedal was uncomfortably hard for everyday driving. I could see why you might do it in a competition car, but a road car, not for me. Each to their own though. The one thing I did change was the little square sectioned O ring on the snout of the cylinder (purple arrow)..... after that cylinder took a clean up..... and everything reassembled. Next up, clutch slave cylinder..... this is such an easy task with the pedal box out of the car as opposed to changing one in place. If you'd like a more realistic experience on how to change a clutch master cylinder in place, then lay crunched up on your back on the floor, and hold the monitor over your head and swear repeatedly at it while reading this...... two mounting bolts and one pivot bolt secure the new cylinder in place...... and with that done the ABS unit, brake pipes and master cylinder could be fitted back in the engine bay...... while the pedal box was rebolted back inside...... Next up, heater motor...... starting up top first with the actual fan motor...... power and earth wire's are disconnected from the motor..... followed by undoing the four tabs on the front of the fan cowls and another four on the rear (softly, softly, 20 odd years of living out under the scuttle panel and they're fairly brittle)...... cowls removed and it's on to pulling the motor out. After 20 minutes of beating chunks out of it I finally figured out the motor retaining clip (coloured blue below) is popped free at the bottom and hinged up...... to allow the motor to lift out..... first up was to check the motor shaft for any play side to side or wibbly wobbly (technical term), if there is, dump the motor and get another, it's not worth the grief trying to change the bearings on these. With that done the only other thing I wanted to check while it was out was the motor brushes, which are under these clips...... Two in total, one each side. Clips just pop off ,and the springs underneath like to head off into the scenery, which turned this particular job into a frustrating fu*king treasure hunt...... with the clips removed you can see the brushes in their little housing..... when slid out they were found to be not even half worn yet, so they're good to go for another long while yet....... Next up was the little resistor pack, which resides just above the water valve on the side of the heater unit...... and sticks out into the incoming air duct area.... it just pulls out...... These can give a bit of trouble now the cars are reaching this age, and a sure sign that ones playing up is when speeds 1, 2 and 3 don't work on the heater anymore but position 4 still works fine. To get a look at the inner bits of the pack the 4 little tabs marked below are bent back...... allowing the metal cover to pop off...... and then you can see the 3 little coils of wire of varying thickness's which make up the 3 resistors...... When you have the heater switched to speed 1, the power leaves the switch and comes to this resistor pack on it's way to the fan motor. When it enter's the pack it passes through all 3 coils of wire (resistors) before going on to the motor. As it has had to push through all 3 resistors the power left when it reaches the motor is small, so the motor only turns slowly. Hence number 1 speed on the fan switch equals soft blow. Number 2 speed power only passes through 2 of these resistors, hence a little more power left when it reaches the motor and as such the motor turns a little faster. Number 3 speed power only passes through the one resistor and the fan motor gets a good wack of juice. And finally number 4 speed doesn't go near the resistor pack at all, it just heads straight to the fan motor and gives her full 12 volt, warp speed. And as such when the resistor pack fails your just left with full speed position 4 or nothing. In the pic below you can see the route the power takes on it's way out of resistor pack. Regardless of which speed it is 1, 2 or 3 they all take this path on the way out. Flowing from the red arrow on the right in the pic, towards the left, through the set of closed contacts (purple arrow) and on down and out the bottom to the wire that brings them to the fan motor. the reason there's a set of contacts is a safety measure. There a fair whack of juice flowing through these resistor coils and as such they can get quite hot, hence the reason this bit pokes out into the incoming air, to help cool it. But, if something happened and they were to get too hot they could become a fire risk, so, in the pic above you can see a tiny bit of metal I've coloured yellow (pointed out by yellow arrow). This metal is bimetallic, meaning that when it reaches a certain temperature it bends. And in this case, if the resistors get too hot, then it bends like in the pic below and seperates the two contacts apart..... now the power can't flow any more on speeds 1, 2 or 3 till the resistors cool down and the little bimetallic strip also cools and flattens out again allowing the contacts to touch again. Unfortunately what happens is these contacts can get dirty over the years until eventually the power can't cross them anymore, where upon the owner/mechanic takes them out fu*ks them away and buys a new set, when 9 out of ten times, popping the cover and using a little piece of sandpaper to clean the contacts up would have left them good to go for another 10 or 20 years. Anywho, next up was the heater radiator and valve. To remove the rad the 3 little screws arrowed below are undone...... however the rad can only slide out so far till the air duct below (red arrow) gets in the way, so by removing the little screw on the side (purple arrow) and popping it's two little retainer clips the vent can be removed.......... allowing the rad to side all the way out...... theres two different types of heater motor's fitted to e30 heater's and as such two different types of radiators to go into them. They are distinguished by the pipes that fit on to them. Below you can see mine has one plastic pipe and one aluminium pipe. So it's the aluminium pipe type. The other type one has two plastic pipes going to it....... Why do i need to know this you may ask? Well, it should help you buy the right type of rad, because the two are non interchangeable, as I proudly display below after buying the wrong one, fu*k...... Must say a quick thanks to the good folk at C3bmw.co.uk, who without quibble took back the wrong rad I had chose and promptly sent me the other one, even though quite a bit of time had elapsed since the original purchace. Good people. As you can see below I now had a perfect match...... The reason this is being changed by the way, is at this age the rad's like to spring a leak and unfortunately the first you'll know about it is when the interior carpet starts to resemble a swamp. The other part thats being changed is the heater valve pipe that bolts up to the rad as these can also fail. Your usually left in no doubt when this fails as when it bursts it can spew out boiling water over your legs. Nice........ new rad comes with a fat and skinny piece of foam..... fat one sticks on around the outside and skinny one around the top like below...... then the new heater valve pipe and the other pipe get bolted back on with some fresh o rings...... after which the rad slides back into place...... and the little 2 pin electrical plug is reattached to the top of the heater valve....... then the motor is popped back into the front section...... and it's retaining clip clipped back down........ wire's reconnected....... and finally the fan shrouds are refitted. The fan shroud have a little groove to sit into. Take a second or two to get this right as if you don't there's a good chance the fan is going to rattle like hell when powered up....... and then she's just about ready to go back in....... last thing to do is fit a pair of foam gaskets. As seems to be par for the course at this stage I ordered the wrong one. I'm still convinced I ordered the right part number, however this is what arrived at the main dealer.... It's the gasket for the other type of heater motor. As you can see though they're pretty much similar, and a quick chop with the stanley knife and they were a lot more similar...... The other gasket was for the inside piece of the heater unit...... After that, the grommet gets popped back in the bulkhead....... and the heater unit gets hammered back in, making sure the 4 mounting bolts pop through their little hole in the scuttle area so you can refit the 4 nuts to them (red arrows), and the two pipes pop through the big grommet in the bulkhead (purple arrow)....... all done..... Hope to get the next final bit of this update up in the next day or two. Till then........... STAY TUNED Bearbeitet: 17. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472620 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 19. Februar 2015 Autor #49 Meldung Teilen Geschrieben: 19. Februar 2015 (bearbeitet) The last of the engine ancillaries to get a spit and shine was the power steering pump. the front pulley is popped off after it's 3 bolts are undone....... and then after you've made a mental note of which way the carrier bracket sits on, the four main bolts that hold the 2 half's of the pump together are undone....... only really interested in the half on the right in the pic above as thats where all the serviceable items live. First up the little face plate lifts off it's two little locator dowels..... and then the cam ring underneath lifts off. A bit of time is then spent checking the inside wall of the cam ring (red arrows), as this surface needs to be super smooth for the pump to do it's job. Any heavy scoring or scratches on this surface and it's over the shoulder with the old pump and off to the scrap yard for a "new one"....... With the cam ring out of the way the 10 little blades can be removed from the rotor in the centre of the pump......... and finally the little circlip at the centre of the rotor is popped off....... allowing the rotor to be lifted off the splined driveshaft....... once the rotor is removed from the driveshaft, the driveshaft can be slid out of the pump housing........ and with that out of the way the little oil seal at the snout of the housing is popped out...... With everything pulled asunder and before the enthusiasm starts to wear off, all the bits are cleaned for reassembly. Everythings got to be fairly spotless in here as a little bit of dirt or grit won't take long to fu*k up your pump or steering rack........ For nailing it all back together the following service kit was bought from the main dealer under part number 32411 135 880. Which contains the following............ 1. snout oil seal 2. hard, face plate seal 3. soft, face plate seal 4. O ring 5. circlip the other item needed for reassembly is a little bit of power steering oil to rub on the bits as they go back together........ First up is the new oil seal fitted to the housing like so...... and once thats in, the driveshaft can be refitted.......... then the rotor is dropped back down onto the splines on the shaft........ and the new circlip fitted........... cam ring sat back into place....... and next to go in are the little blades. 10 of these in total and you need to be a little careful when dropping them back in. The reason being, one end of these are curved smooth and the other end is flat. If I owned a camera that didn't need a fu*king masters degree in technology to zoom in on something I would have taken a picture of this, however, I don't, so I drew a picture instead....... As above the rounded face goes to the outside, up against that smooth wall of the cam ring, the inside flat face points towards the centre of the rotor. Get them wrong and your pump won't pump for long....... All the bits in the pic's above and below are given a rub of power steering oil as they're dropped in by the way. With that part done the face plate is dropped back onto it's dowels....... and then first the soft seal is dropped into the little recess on top (red arrow), followed by the hard seal (purple arrow)........ a bit hard to see below but the hard seal go's around the outside of the soft seal....... final bit to go in is the big o ring....... and then after giving everything a good smear of power steering oil, the two halfs of the pump get bolted back together making sure that the two little ports marked below (black arrows) face each other...... Once back together everything outside gets a lick of paint........ Bearbeitet: 19. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472837 Auf anderen Seiten teilen Weitere Optionen zum teilen...
Kurt66 Geschrieben: 19. Februar 2015 Autor #50 Meldung Teilen Geschrieben: 19. Februar 2015 (bearbeitet) After that it was on to some light work...... E30's seem to be fairly prone to water leaks around the tail lights, so, the new gaskets were given a light coating of grease on the side that sits against the light.......... and the mating surface that they sit up against on the car was also given a light smear...... before the lights were hammered home........ reg plate lights had decided to tint themselves brown somewhere along the last 20 odd years so I changed them back to clear........... the area around these little lights also seems to like rusting, so, some fresh clips were fitted and suffocated in grease before the lights were screwed back in...... With the rear end done it was on to the front lights, which looked like they'd gone ten rounds with a sand blaster, and lost........ The headlight rims were in a bad condition, so I sent them away to have them rechromed..... and then it was on to stripping the headlights themselves. Theres two different brands of headlights for e30's I think, and these are the Hella variety. Bulb covers twist off first....... and then 3 little screws are undone to remove the reflector..... Then 4 little screws are undone to remove the front glass section from the reflector in the pic above. The glass bit can be cleaned up normally, but, the chrome "bowl" in the pic below needs a bit of caution when cleaning. The chrome is 20 odd years old and and lived in a hot/cold environment for that length of time (headlights on/off), and as such it needs to be treated delicately. Squirt some glass cleaner in here and go at it with a rag and you'll just wipe all the chrome away. So "softly" rub away any dust with some cotton wool....... next up replacing the lenses. Each one is held in place by 3 adjusters (well actually 2 adjusters and 1 pivot lug)........ these are removed first from the headlight surround by twisting them till the little white plastic rectangle lines up with the rectangle on the housing like so...... allowing the two lights to be removed from the frame....... then the adjusters had to be removed from the old lenses and swapped over on to the new ones, making sure the 2 adjusters and 1 pivot lug go in the exact same location on the new headlight, otherwise your going to be dazzling passing airplanes...... adjusters can be a bit of a pig to remove. In the pic below you can see the little plastic "socket" they use to sit into the light frame. All 4 corners of this little socket need to be pushed inwards to allow the socket and adjuster to lift out together...... Then some fresh lenses are added..... adjusters are refitted (making sure they go back into their right holes)....... and then they're popped back into the frame...... and finally the reflectors and bulbs are refitted to leave them looking a whole lot fresher...... Chrome rims for the outside of the lights still haven't returned back from chroming yet, as, amazingly, I seem to have found someone who works even slower than I do. And thats about it for this update. Next up, is the black magic thats required to keep the smoke inside the wiring looms......... Till then................ Bearbeitet: 19. Februar 2015 von Kurt66 Zitieren Link zu diesem Kommentar https://e30-talk.com/topic/110759-e30-m3-minor-rust-repair-thread-restauration-finished/page/2/#findComment-1472838 Auf anderen Seiten teilen Weitere Optionen zum teilen...
